check engine light after c&l install
I found a list of codes on the web a few days ago.
ASSuME-ing that this list is right, here is the P0605 code:
P0605 Internal Control Module Read Only Memory (ROM) Error
If I were you, I'd try loading the tune again, and see if you get the same results. If the problem reappears, contact your vendor ASAP and get their help.
okay,hold the phone!i went back into the code reading par tafter i found out how to do this and turned the code off.after about 50 miles and 5 or 6 stops and restarts it hasnt come back.friend of mine said this happens a lot and shoudnt come back on.one thing i dont like is the instruction are very lack luster on how to make any changes.but man it really makes a auto run alot better.
Diode Dynamics
6/12/18 03:26 PM
