check engine light after c&l install
I found a list of codes on the web a few days ago.
ASSuME-ing
that this list is right, here is the P0605 code:
P0605 Internal Control Module Read Only Memory (ROM) Error
If I were you, I'd try loading the tune again, and see if you get the same results. If the problem reappears, contact your vendor ASAP and get their help.
ASSuME-ing
that this list is right, here is the P0605 code:P0605 Internal Control Module Read Only Memory (ROM) Error
okay,hold the phone!i went back into the code reading par tafter i found out how to do this and turned the code off.after about 50 miles and 5 or 6 stops and restarts it hasnt come back.friend of mine said this happens a lot and shoudnt come back on.one thing i dont like is the instruction are very lack luster on how to make any changes.but man it really makes a auto run alot better.
Diode Dynamics
Jun 12, 2018 03:26 PM
