Charge motion plates, when do they open?
Old Aug 10, 2008 | 12:38 PM
08VistablueGT's Avatar
As the title says. I need to know at what RPM they open. This will dictate when I activate my window switch for nitrous.
Thanks,
Brandon
Old Aug 10, 2008 | 02:35 PM
2kanchoo's Avatar
What kind of nitrous kit? Why not get the delete plates? Steeda makes a set that come with the openings for a wet nos kit already on em.
Old Aug 10, 2008 | 09:53 PM
I know they do. A wet kit.
Old Aug 10, 2008 | 09:57 PM
jaguarking11's Avatar
~3000rpm
You will notice that when you are at wot and the sound of the engine changes from the raspy beast it is to a loduer raspier note. However they might open sooner at around 2700rpm as well. It is controlled by the ecu.
Old Aug 11, 2008 | 12:44 PM
2kanchoo's Avatar
You know that they get rid of the butterflies so you wouldn't have to worry about them being open or not right.
Old Aug 11, 2008 | 02:16 PM
Yes. Hence a delete plate.
Old Aug 11, 2008 | 04:01 PM
jamesdem1123's Avatar
its recommended to set the switch to open at 3000 anyways so theres enough suction to reduce fuel puddling and possible intake back fire. ive seen that on a cobalt, blew the composite intake apart. you would need the charge motion plates open when you use the juice. can you change the opening rpm with a tune?
Old Aug 11, 2008 | 04:49 PM
Probably. I'll ask my tuner. I have the window switch set to activate the nitrous management unit at 3,200 RPM.
Old Aug 12, 2008 | 03:12 AM
NMU.. you must be going with the zex kit. let me know how the fogger nozzle works out. i ordered the Nitrous express plate set up. im not sure how well either of them will work but i hear good things about both companies. does zex measure hp increase at the tire or the crank? how big of a shot are you running? fuel upgrades?
Old Aug 12, 2008 | 02:00 PM
I'm not sure how they measure it. I will be running a 150 and 100 shot. I have a KB BAP along with Brisk 2 step colder plugs.
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
