Changing the transaxle fluid ?
Old Jan 24, 2013 | 01:10 AM
sebvegas's Avatar
Hey everyone,
OK so I have to change the engine oil on my '06 GT and was planning to do as well the transmission oil.
But I asked my mechanic about the rear transaxle oil and he told me that I don't need to change it unless it's leaking.
Do you guys know anything about that ? We really don't need to change the fluid for the transaxle ? Is it good for the car lifetime ?
thanks a lot to everyone
Old Jan 24, 2013 | 08:33 AM
muscledom's Avatar
Trans fluid needs to be changed somewhat regularly if its an auto. As far as gear lube goes, it can't hurt to change it but its probably not necessary.
Old Jan 24, 2013 | 09:33 AM
sebvegas's Avatar
OK thanks So I guess I do not need to change it, no leaks and never went into water.
Old Jan 24, 2013 | 12:17 PM
I typically don't change the oil in the differential until 100k or so.
btw - you do not have a transaxle in a Mustang GT. You have an engine mated with the transmission, then a rear axle differential (Traction-Lok) connected with a drive shaft.
Whereas most mid engine cars have an engine mated with a transaxle - where the transmission and differential are an integrated unit. Notice how the axle (half-shafts) mounts are located at the transmission - no drive shaft needed.
Ford GT Engine & Transaxle
Old Jan 24, 2013 | 12:20 PM
Nrgahan-94GT's Avatar
Changing the rear end fluid is overkill just spending an extra 50+ bucks
Old Jan 24, 2013 | 01:09 PM
sebvegas's Avatar
Thanks everyone I learned a lot with you.
Being French, I don't know all the technical terms for all this stuff.
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
southern stang
Sep 26, 2015 04:19 PM
