changing the pinion angle
A question for owners with adjustable LCA's...
For a lowered suspension (1.25" to 1.5")...to get better traction, were adjustable LCA's enough, or did you also need the LCA relocation brackets?
If I want to change the pinion angle and eliminate wheel hop and get better traction--should I lengthen the LCA?
Thanks. The "instant center" is what I was meaning to say, in spite of my subject line. I guess my original question can better be phrased...Can I impoved the instant center by using only adjustable lca's? or will i need the relocation brackets?
For otimal instant center I would pick up either the BMR or CHE LCA relocation brackets. If you look at your LCA's you will notice that the axle end is now higher than the chassis end when the car is sitting on level ground. For your drop I'd use the upper hole. This would put the LCA's near level.
Also once the LCA relocation brackets are installed a pinion angle adjustment is recommended. -3degrees is ideal.
Adjusting pinion angle will not have any significant change on the instant center (IC), To change IC favorably after lowering , you need to drop the back of the LCA and drop the back of the UCA. This will correct the IC by raising it. Go to the BMR web site to see thier kit. The rear axle bracket has two additional lower anchor points to tune to.
Rando
8/25/21 11:12 AM
DerekShiekhi
9/30/15 06:59 AM
