Changing out rear end gear oil
Old Jul 27, 2005 | 03:08 PM
Hatchman's Avatar
Looking to change out the rear end fluid soon with some Amsoil. Anybody have instructions or pics on how to do it? Looks like you unbolt it, drain the fluid, bolt it back up with fresh gasket sealer (Permatex black?), and fill her up to a little below the fill hole.
How's that sound?
Old Jul 28, 2005 | 05:56 AM
Hatchman's Avatar
How's that sound?
Please help! Changing out today. Thanks!
Old Jul 28, 2005 | 09:52 AM
The Lyin' King's Avatar
I haven't done mine yet so I can't say for sure whether there's a gasket or if they just used sealer.
You can call the parts department at your local dealership and they should be able to tell you. You'll need to swing by there anyway as the LSD in GTs requires that a friction modifier be added with the gear lube.
Other than that the procedure is as you have stated.
Old Jul 28, 2005 | 12:18 PM
Stoenr's Avatar
VIa the fill hole, we use a little tube with a pump on the end, and let gravity do the work.
Looks like a clear oversized bycycle pump.
Works pretty good
Old Jul 28, 2005 | 12:19 PM
Satin Silver 05's Avatar
I dont know the name of it but you MUST use conditioner for the trac lok diff. or you will ruin the clutches. call your service department at Ford
Old Jul 28, 2005 | 02:44 PM
BlueCar's Avatar
[attachmentid=28864]
Old Jul 28, 2005 | 03:26 PM
Hatchman's Avatar
I got the friction modifier too! Thanks for the tips, and the instructions, awesome!
Ecostang
Nov 3, 2022 08:50 PM
chadh92
Jul 29, 2015 06:56 AM
Ecostang
Jul 11, 2015 09:06 AM
Kev006
Jul 8, 2015 05:29 AM
