Change plugs and coils, but issue?
Old 6/11/13, 03:29 PM
Ouch!
Old 6/11/13, 03:31 PM
Corstang427's Avatar
Originally Posted by cdynaco
Ouch!
Yeah ouch to my wallet :/.
Old 6/11/13, 04:28 PM
shaunrc's Avatar
Sorry to hear that man that sucks
Old 6/11/13, 05:17 PM
Most expensive part will be the head studs. $400 although if they will prevent any future issues then they are worth the money.
Old 6/11/13, 05:31 PM
shaunrc's Avatar
[QUOTE="Corstang427;6639064"]Most expensive part will be the head studs. $400 although if they will prevent any future issues then they are worth the money.[/QUO
The head stud kit will make it easier the next time you have to take your head off that's for sure just make sure you use sealer for the threads or you'll be doing the same repair later down the road
Old 6/11/13, 05:32 PM
shaunrc's Avatar
I don't know how I managed to get my response in your quote sorry
Old 6/11/13, 06:32 PM
What type of sealer do you recommend?
Old 6/11/13, 06:37 PM
While I have the valve covers off they are getting powder coated.
Old 6/11/13, 08:03 PM
shaunrc's Avatar
Permatex ultra black rtv is what I have used and it works great not one problem
Old 6/11/13, 09:22 PM
muscledom's Avatar
Blew a head gasket, so I'm installing a new one and putting in ARP head studs. Hope this will prevent another one.
Dude that's so weird. Did it overheat? What year? How many miles? Crazy how the plug valleys filled up like that. Very puzzling.
Old 6/11/13, 09:51 PM
Didn't over heat, 06, 5800 miles. Thinking that me getting hard on the throttle and the boost lifted up the head gasket enough to allow traces of coolant in there. Only thing we could think of.
Old 6/12/13, 05:38 AM
muscledom's Avatar
Dude that's crazy. Maybe boost. Still weird.
Old 6/12/13, 06:47 AM
Bear Eats King...
Bear ****s Bone
texastboneking's Avatar
Me and my buddy looked at it last night. He builds motors for a living. Showed me that in each spark plug well has an oring at the top. He thinks I lifted all those. Don't think it's head gasket bc no oil. Checked oil it is fine.
With this comment^^ I question your buddies engine rebuilding skills.
What was the Compression on each cylinder?
How much boost you pushin?
Old 6/12/13, 07:19 AM
I apologize on that it was the sleeves he was referring too not o rings. That was my fault. I couldn't remember what he said that late night. It's my lack of knowledge not his lack of skill. I'm a biology major not a mechanic. 10 lbs of boost.
Old 6/12/13, 07:55 AM
Bear Eats King...
Bear ****s Bone
Makes more sense
Old 6/12/13, 09:28 PM
Can I change the head gaskets in the engine bay or do I have to pull the engine?
Old 6/12/13, 09:41 PM
shaunrc's Avatar
I have heard of people changing their cams while the motor was in the car but it may be a little difficult plus it is open to debris from the engine bay to get into the cylinders also you may want to machine the heads to get rid of any imperfections that caused the problem in the first place
Old 6/12/13, 09:52 PM
Bear Eats King...
Bear ****s Bone
yes. i wouldnt pull the engine just for headgaskets. got alot of work cut out for you. if you were local i would help
Old 6/12/13, 10:05 PM
How much would that cost?
  #40
Could you tell me everything I will need to do this?
Quick Reply: Change plugs and coils, but issue?
