Car/Motor Buildup in Progress
Old Nov 23, 2007 | 10:09 AM
94tbird's Avatar
Well i figured i would update everyone with the latest happenings on this long overdue project. Lets jsut say issues arose, i gave up my spot both for the motor build and the motor install because it was the right thing to do for the situations the people i gave my spots up to were in. Hell i even gave up my Block, Pistons, rods, and Crank LOL.
Anyway The car is currently at Piedmont Modular Performance in Salisbury, NC in the capable hands of Josh and Kevin. Larry delivered the motor about 2 weeks ago and Steeda (FINALLY) shipped the transmission after ordering it back in August. We are waiting for the TR6060 to be fully disassembled (it hasn't even had fluid in it yet haha) so the gears can be removed and polished. Then the entire Transmission will be Cryo Treated to improve the strength. Once reassembled and delivered back to PMP, The engine will go in along with a whole mess of other parts.
Motor Specs:
Teksid Block
Cobra Crank
Manley H Beam Rods
Ross 17cc Dish Pistons(Thermal Barrier Ceramic/Hard Skirt Coating)
Fel Pro Gasket Set
ARP Bolts
Livernois Stage 3 Heads
BBR Stage 2 Cams
Boss330 Adjustable Cam Gears (locking out VCT)
Canton Windage Tray
Moroso 7qt Deep Sump Oil Pan
Innovators West 18% Overdrive Pulley
8 Rib Kit
HT0 Spark Plugsa
Suspension/Drivetrain/Chassis:
TR6060, Cryo Treated and Gears polished
GT500 Twin Disc Clutch
Pro 5.0 Shifter
BMR K Member with Lowered Motor Mounts
BMR Boxed Subframe Connectors
BMR Panhard Bar Brace
AutoPower Rollbar(will be modifying it to have removable door bars and welding in the rear bar)
Custom Made Driveshaft to fit the Currie 9" Rear and the TR6060
Induction:
ST Motorsports Mono Blade TB
ST Motorsports Custom Intake Tube
ST Motorsports Ported KB Blower Manifold
KB Big Bore Filter
HPX Custom MAF
Fuel System:
PMP's Fuel System (Twin Ford GT Supercar Pumps with dual feeds, feed a y block to a single line to engine bay, feeds a y block to feed each fuel rail individually with a crossover for a backup)
Metco Fuel Rails (customized by PMP to fit with KB Blower)
83lbs Injectors
Cooling:
7 gallon Fuel Cell gutted and mounted in the Spare Tire Well for cooling the intercooler
Nitrous System:
Ny-Trex Nitrous System With Purge, Blow Down Tube, And Pressure Gague
Dyno Tune Bottle Warmer
Dynotune 2 Stage Window Switch/TPS Switch with Gear Lockout
150 shot Jets
Interior/Exterior/Dressup:
SOS Triple Dash Pod, Drilled version
SOS Switch panel
Autometer Oil Pressure Gauge, Nexus Series
Canton Power Steering Reservoir
Dynomax Resonators to get rid of Trumpeting
The nice thing about this motor is, I am not using one single part off of my stock motor. It was built completely independent of it to minimize downtime, and so that i can keep the stock motor, sell it, tear it apart and rebuild it, or whatever i want to do with it as it is a complete longblock. I Will also have the stock transmission as well. I may get that sent out to Promotion and have it refreshed and upgraded and sell it.
We are planning on running 20psi of boost through the 2.4L KB and having the Ny-Trex system not only cool the intake charge in addition to the ability to run ice in the 7 gallon tank in the trunk, but to boost the HP and torque output a bit.
That shoudl about cover it for the moment. All parts are paid for. Basically waiting for the transmission to be finished and then the engine goes in and gets tuned. Since i live in NY im in no rush to pick it up (**** winter) so they can take as much time as they want now haha.
Old Nov 23, 2007 | 12:22 PM
soitsav6's Avatar
all I can say is HOLY CRAP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 23, 2007 | 01:31 PM
anthony05gt's Avatar
Sounds like a beast
Old Nov 23, 2007 | 01:46 PM
70MACH1OWNER's Avatar
That will be one he!! of a ride when she is done!!
Scott
Old Nov 23, 2007 | 02:41 PM
Bullitt995's Avatar
What kind of compression ratio are those pistons going to give you?
Old Nov 23, 2007 | 02:55 PM
GRAYPNY's Avatar
Aren't go going to the darkside with twin turbos Ron?
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
Sep 16, 2015 06:44 PM
mrkabc
Aug 26, 2015 05:41 PM
mrp5150
Aug 23, 2015 06:29 AM
Jul 30, 2015 06:47 AM
