Car goes into Safe mode every time
Old Oct 29, 2005 | 07:47 PM
mikem's Avatar
I am getting so pissed at this car.Every single time I pull up to the water box and start my burnout,The car goes into Limp Home Mode.I am getting real close to ripping engine and computer out and going old school.When is someone going to be able to get rid of this mode?
Gives no codes usually but today it did.But the codes seem to just say Hey...........We shut you off because we dont like you>>>
codes
PO616-----Unknown
P2106----- Throtlle actuator control sysyem
P1000-----System Reading
Please help,help ,help...........................
Old Oct 29, 2005 | 10:06 PM
wild stray's Avatar
I was going into failsafe continually at WOT and showed P2106. I believe it was due to the tune not being up to the cmd mod. You don't show you have the cmd, but I would suspect your current tune. I was also getting code P061B at the same time, sometimes.
Old Oct 29, 2005 | 10:33 PM
Mongoose's Avatar
I would be pissed also.
Old Oct 29, 2005 | 10:39 PM
Cleveland's Avatar
You, my friend, need to speak with a tuner real quick and get him a datalog. The datalog should reveal the issue.
-Dan
Old Oct 30, 2005 | 01:39 PM
Doug@C&L's Avatar
The code is a throttle issue, Shoot me an email and send me your list of mods along with your calibration code. I'll send you a tune for you to try. I'm pretty sure I know what the issue is as alot of SCT dealers still don't have access to the electronic throttle adjustment they are leaving out a major part of the programming and causing some cars to go into limp mode when they upgrade gears.
thanks, Doug.
BamaChips@gmail.com
Old Oct 30, 2005 | 02:21 PM
dustindu4's Avatar
9 is not my lucky number.
doug is a great guy
Old Oct 30, 2005 | 03:57 PM
Doug@C&L's Avatar
Well, I figure if this fixes his problem then he can contact his SCT tuner and have them modify his specific files using these adjustments and if not then he's only out 5-10 minutes of his time. Let's hope for the best
Old Oct 30, 2005 | 06:23 PM
dustindu4's Avatar
Well Blazing Saddles goes to the same tuner and he has the same mods pretty much and doesn't have the problem.
Old Oct 30, 2005 | 06:33 PM
wild stray's Avatar
I never had a problem with my tuner until my last (fourth) tune and he wasn't available to correct it. I received a tune from Doug and havn't had a problem since.
Paul
Old Jun 17, 2006 | 01:32 PM
mikem's Avatar
It ended up Being my TPS sensor.Got it replaced at Ford.Perfect now no codes since.
Old Jun 18, 2006 | 12:45 PM
Bullitt995's Avatar
Same thing happend to me. I was about to suggest going to the dealer.
Old Jun 18, 2006 | 08:35 PM
atomic_il's Avatar
What is a TPS sensor... does this sense when TPS reports don't have covers?
Old Jun 19, 2006 | 12:08 AM
TerpGT17's Avatar
I had the same problem, once my TPS was replaced the car ran fine again. A throttle position sensor is pretty much what its name implies I think. It detects how much throttle is being fed in and operates the throttle body accordingly. When mine was defective I had a very inconsistent idle and the engine would surge without me giving it any gas.
Old Jun 19, 2006 | 10:51 AM
mudshuvel319's Avatar
Actually, it determines whether or not you have the recommended 37 peices of flair.
Seriously though, TPS is Throttle Position Sensor
Old Jul 13, 2006 | 01:02 PM
Iceman20v's Avatar
wheres the tps?
So can anyone tell me where the TPS is located. I'm guessing it is probably on the throttle body, but I would like to know before I take the car in since I don't have a stock throttle body.
Old Jul 14, 2006 | 06:47 AM
eat.the.rude's Avatar
Nope - that's not it. The TPS sensor determines if the guy that wrote your tune used a TPS cover sheet like he was supposed to
Yeah. If you could just go ahead and make sure you do that from now on, that will be great. And uh, I'll go ahead and make sure you get another copy of that memo mmm'k?
Old Jul 14, 2006 | 11:44 AM
dustindu4's Avatar
On the drivers side of the TB at the top, there's a little square wire connector on it. I bet they are cheap if you have to buy one and every dealer stocks them.
Old Jul 14, 2006 | 12:45 PM
Iceman20v's Avatar
My best 1/4 and 60' are almost identical to yours dustin. So I am guessing that this problem could be robbing me hp since I have a couple more mods than you. I would really like to break into a 12. Oh so close.
PonyShow
V6
Nov 17, 2017 02:00 PM
tony2014mustang
Feb 27, 2016 12:09 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
Extremespeedtrackevents
West Coast
Jul 28, 2015 12:49 AM
West Coast
Jul 9, 2015 11:26 AM
