camber plates and panhard bar
Old Mar 5, 2008 | 07:46 PM
oneunderone's Avatar
i lowered my car with prokit and was wondering how do you know if you need caster camber plates
do you all recommend i get a adjustable or non pan hard bar
Old Mar 5, 2008 | 08:37 PM
Cavero's Avatar
I can't answer about the camber plates, but as far as the panhard bar goes, the answer is adjustable if you need to get one. Since its already lowered, you can check to see if your rear wheels are still centered laterally with respect to the body (i.e see if one sticks out more to one side than the other). If its not centered, you'll need a new panhard bar to correct it, and it's going to have to be adjustable. I'm going to take a wild guess and say that non-adjustable is probably the same length as stock which means it won't do squat for side-to-side alignment.
That said, the two best choices are made by Steeda and BMR Fabrication. I have the Steeda and its kind of a pain in the *** to adjust (adjustments are made at each end, one of which is obstructed by a bracket) and I had to use Locktite to keep it from loosening. Those two initial problems aside, its pretty solid, and I haven't had any problems since the initial install. The BMR offereing is much easier to adjust (ajustments made towards the middle of the bar) and I've never heard anything bad about it.
Old Mar 6, 2008 | 05:59 AM
I got away with just camber bolts about 30 bucks at the local auto parts store. I did use an adjustable pan hard rod as well
Old Mar 6, 2008 | 06:09 AM
colbymh's Avatar
I just had more suspension work done on mine and also used the BMR adjustable panhard rod, Steeda bumpsteer kit and the camber kit.
I dont think you need the camber kit unless you add the bumpsteer kit.
But definitely get an adjustable panhard rod. mine was I think $185 through stangsuspension.
Old Mar 6, 2008 | 11:04 AM
mot250's Avatar
I was also a little miffed about the adjustment jam nut position on the Steeda bar I installed over the weekend also. I ended up getting the chassis side (passenger side) jam-nut tight by turning the bar an additional 1/4 turn away from the jam nut. Then I made sure the jam nut was where I wanted it and I wedged a pry-bar between the mount and a flat on the jam-nut. Then I turned the bar "locking" it against the jam nut (be sure the end of the bar tube with the flats is on the axle side (driver side)). Lastly I tightened the the axel side jam nut against the tube. I have not yeet driven the car so I can't say yet if that was tight enough to keep it in position but I'll be sure to check it and add thread lock if it loosens up.
Old Mar 6, 2008 | 03:37 PM
blkstang06's Avatar
I use the J&M posted here! both jamb nuts accessible !
2005-Pres. Ford Mustang Billet Aluminum Double Adjustable Panhard RodMustang - 2005-2008 MUSTANG#23757
Click to Enlarge
Click to Enlarge
Years:
2005, 2006
2005 Ford Mustang - Street/Race Adjustable Panhard Rod
Our tubular adjustable panhard rod is the finest on the market today. Manufactured from high strength 1.125" x .210" 6061-T6 aluminum, our ultra light panhard rod will eliminate unwanted flex and twist. The panhard rod will give you the competitive edge by keeping the rear axle located in the optimum position under the rear of the car. Thereby, dramatically improving cornering and overall handling predictability. The rod can be easily adjusted on the vehicle to compensate for ride height adjustments. Our panhard rod features machined wrench flats with left and right hand threads allowing fast and accurate adjustments while still on the vehicle.
Only $139.82!!
Qty: Home | About Us | Products | Specials | Links
Old Mar 6, 2008 | 04:54 PM
the camber kit and the bump steer kit do two different things.
Old Mar 6, 2008 | 05:00 PM
Steve@GMS's Avatar
Unregistered
We have had good success with our adjustable pan hard bar.
Old Mar 6, 2008 | 07:01 PM
RadBOSS's Avatar
After lowering you need to get the front end aligned. That will tell you if you need camber kit or not.
Old May 19, 2008 | 09:41 PM
Jon_Purdy's Avatar
I'm lowering the front 1" and the rear 3/4" next month. I have camber bolts but will that be enough?
Jon
Old May 19, 2008 | 09:50 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Camber bolts and a Spohn Adj PH Bar for me. (FRPP springs)
Old May 19, 2008 | 10:01 PM
Jon_Purdy's Avatar
Could someone please post a pdf of the front suspension?
Old May 19, 2008 | 10:26 PM
Jon_Purdy's Avatar
What part number do you have for the camber bolts? I just to make sure I've got the right ones. The part number I have is 4R3Z-3B236-AB
Old May 20, 2008 | 10:04 AM
I lust for a M24
Sorry bro, I don't even know. The alignment shop ordered them and put them in when they did the alignment. I just got my old bolts back.
Old May 20, 2008 | 07:31 PM
Boltzman's Avatar
I got camber bolts and had the front end aligned. I got lucky and did'nt need a panhard bar
robjh22
Dec 14, 2015 08:41 AM
RoushRS3
Sep 29, 2015 08:03 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
Evil_Capri
Sep 25, 2015 12:56 PM
robjh22
Sep 8, 2015 12:31 PM
