Are Camber Bolts sufficient, hope so?
Old Sep 18, 2013 | 09:53 PM
Mungodrums's Avatar
I hear some vender's say that one must run caster / camber plates. Others say Eibach or BMR camber bolts are good enough. Planning on running BMR springs or Steeda Sport springs, BMR front / rear sway bars, BMR Panhard bar, Ford upper strut mounts and BMR camber bolts. Mostly daily driver with some occasional weekend tracking / road racing. Thanks, Ger.
Old Sep 18, 2013 | 10:59 PM
bob's Avatar
bob
I run 2 degrees of negative camber and so far all is well, I just made sure my toe setting was spot on.
I'd install the springs and see where the camber falls. I doubt it would be excessive so just make sure your toe is correctly set and you shouldn't require any form of camber adjustment unless that's what your looking for.
oneeyedgiant
Nov 16, 2015 12:23 PM
boz
Oct 1, 2015 04:47 PM
AJ_Trevino15
Sep 28, 2015 07:51 AM
