CAI installation
Old Jan 6, 2007 | 12:14 PM
sams66's Avatar
CAI installation
I was under the hood taking a look at how hard it would be to do the CAI install. How do you unhook those lines from the valve cover to the factory intake tube, undo the green tabs?
Sam
Old Jan 6, 2007 | 12:49 PM
Mustang Buster's Avatar
Sam
Yeah Sam, just look closely at the green tabs and you will see how they are supposed to come off. Then just pull straight up and the line will pop right off.
Old Jan 6, 2007 | 01:04 PM
RedDragon777's Avatar
ok i had this same problem, check it out feel under the connector and you will feel this little peice sticking out push that forward and it will unhook then you pull it out while you are pushing the tab, here are some pics of the tab, believe me it took me weeks to figure this out LOL
notice how the tab just pushes back:
here is a view of the tab from up front
Old Jan 6, 2007 | 03:42 PM
Cavero's Avatar
Cold Air Intakes are pretty easy to install. Just disconnect the negative battery cable, undo the hose like RedDragon said, disconnect your MAF, undo the one 10mm bolt holding the box down, and then finally loosen the hose clamp at the throttle body and pull it out. Then use the manufacturer's directions for installation. The Granatelli intake took me about half an hour as i figured everything out but I can literally swap back to stock in a little under 5 min.
Old Jan 6, 2007 | 04:14 PM
SteelTownStang's Avatar
I agree that it is very easy, but I've never disconnected the battery.
Old Jan 6, 2007 | 08:32 PM
Northwest GT's Avatar
Leaving the battery connected will probably not cause a problem, but it is generally good practice to do so. You have to disconnect the MAF, so disconnecting the battery is the right thing to do. It's no sweat taking off the battery ground lead. And, probably good insurance.
Having said all that, I did not disconnect the battery when I put in my CAI, and nothing bad happened. But, anyway...disconnect it just to play it safe.
Old Jan 6, 2007 | 09:41 PM
took me 10 min to install the intake and 5-7 min to tune but after the first tune it only takes like 1-2 min to tune, i did not disconnect the battery, and even though the instructions, say to take out the fan and another fuse to tune it is not needed
Old Jan 7, 2007 | 08:46 AM
sams66's Avatar
Thanks guys, this site is so helpful. I didnt want to snap off the connector by forcing it.
Sam
Old Jan 7, 2007 | 01:08 PM
blackstang06's Avatar
Yeah, the install took me around 40 minutes. It's really not that bad compared to the headers I'm trying to install.
Old Jan 7, 2007 | 04:10 PM
G.T's Avatar
G.T
i've taken a bunch of shots while installing my JLT-II which you can view Here
hope this helps
Old Jan 9, 2007 | 02:57 PM
sams66's Avatar
that JLT just secured by the connection to the throttle body? no other clamps? does it move around or is it pretty secure?
Sam
Old Jan 9, 2007 | 03:04 PM
G.T's Avatar
G.T
Just like most Aftermarket CAI, It's secured by the elbow onto the throttle body, and rests onto the heatsheild.
there's barely a few mm clearance when the hood is closed, so it aint going anywhere
Old Jan 9, 2007 | 03:06 PM
Sam, here's another reference for you. K&N CAI install
Old Jan 9, 2007 | 03:46 PM
JRay05stang's Avatar
I personally would not tell you stock airbox GT what if you have to replace it for future warranty work?
Old Jan 9, 2007 | 03:47 PM
sorry I have had no sleep... I ment to say I would not see your stock airbox G.T.
Old Jan 9, 2007 | 04:06 PM
G.T's Avatar
G.T
Justin.. you do seem a bit tired
don't worry.. i didn't sell it.. was being a bit sarcastic in the comment there
p.s: i already used the stock airbox once a month back when i sent her in for warranty repair and had the throttle body replaced.
Old Jan 9, 2007 | 04:50 PM
Sam
It's clamped to the TB and rests on the heat shield. No need to worry... it's not going anywhere. Actually, it's very secured...
Old Jan 9, 2007 | 06:13 PM
some people do not even use the heat sheild and have the JLT II first gen heat sheild that did not surround it was just a big peice of plastic and the intake still held up
Old Jan 9, 2007 | 11:41 PM
Lol just making sure buddy! I figured it was sarcastic just had to make sure!
Old Jan 10, 2007 | 12:17 AM
P.S. I have had a nap and I remember how to spell sell! Man I looked like an idiot 2 post in a row!
FromZto5
Sep 30, 2015 05:28 AM
Grabber5.00
Sep 13, 2015 06:53 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
