C&L Filter Cleaning
Just saw a post about the JLT filter cleaning.
I have the C&L... can I just use the K&N filter stuff to clean it?
Could I possibly use another abbreviation in this post?
[quote name='Imatk' date='April 20, 2006, 2:42 PM' post='667995']
[/quote
Yea, I have the mmr and I just use the K&N stuff to clean it too. Mainly cause when It was time to clean it I didn't want to wait for it to arrive in the mail. Its all the same stuff basically, it all is designed to clean filters. As long as it is'nt a dry cone filter there might be different stuff for that but not sure.
[/quote
I normally do my filter cleaning like every 2-3 oil changes. depending on where you live, check your filter at the next oil change, if you can no longer see the maroon color oil, then clean it.
<div class='quotetop'>QUOTE(MaverickMLFD371 @ April 27, 2006, 11:37 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
That's too often. K&N filters can go a lot longer than that and actually flow better when their is dirt on there. Check out K&N's website for more info. I plan on cleaning my S&B fliter at 25K.
[/b][/quote]
very easy to clean---tapped out the dirt and loosened with soft bristle paint brush---applied cleaner for twenty minutes---rinsed with tap--boy oh boy---that thing filters out some serious grime! made sure to fully dry filter using fan----reapplied oil---walla! she sounds meaner this morning! [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] ---i would recommend every 8-10K----
I have had my v6 for a little over a year, and my intake for prolly 8 months. It is a steeda, and is starting to lose its blue color. Does this mean it needs to be cleaned? My car is not a daily driver and has about 3.5k on it.
