buying a used SCT2 tuner with dif cal code
Old Apr 6, 2008 | 06:44 PM
slipnotovk's Avatar
i am in the process of buying a used SCT2 tuner but the seller's calibration code is different from mine. is it still possible for me to use it on my car? or will i have to get all new tunes. the seller says he is setting it back to factory and it will have 87 89 and 93 race tunes on it. also, he says that it is "unlocked" and that i will have no problem. can anyone give me some insight on this because when it comes to the tuners i am completely lost
Old Apr 6, 2008 | 06:47 PM
GRAYPNY's Avatar
The only way that you could use the tuner is if it is unlocked and has the same calibration code. I "think" you can unlock it on the SCT software that you can download. Buy some tunes from Brenspeed and load them and forget about the SCT canned tunes. If you have a good tuner in your area with a dyno that's even better.
Old Apr 6, 2008 | 07:26 PM
slipnotovk's Avatar
he says it is unlocked. so that means when i get it from him im going to have to order a set of tunes from brenspeed or bama and upload them to the sct? i can do that even though my cal code is different or is it completely unusable because of this **** cal code. im going to have to ask this seller if he has the USB cable for the sct2 tuner so i can do this.
Old Apr 6, 2008 | 09:12 PM
GRAYPNY's Avatar
Call Brenspeed in the morning and tell them what's going on. They will give you the right information and if need be they can load the tunes for you.
Personally I would forget about buying the used tuner and buy it from a tuner that will give you tech support and updated tunes as your mods change.
Good luck~
Old Apr 6, 2008 | 09:15 PM
giddy_up's Avatar
it has to be completely unlocked...i.e. no tunes on it and you will need to purchase a new tune to make it work.
as stated call brenspeed,doug,or any reputable sct tuner,and they will explain it to you.
Mar 30, 2021 09:29 AM
trackpack13gt
Jul 25, 2017 05:29 PM
Bryanh24
Oct 14, 2015 08:43 AM
boz
Oct 1, 2015 04:47 PM
