Burnin rubber with automatic 05 GT
Old Mar 14, 2005 | 12:26 PM
LordBritish's Avatar
I'm having a hard time squeeling the tires when launching in my automatic 05 GT.
I can do it sometimes but not always.
I must have traction control on or something.
How do I burn rubber with an automagic 05 GT?
I used to be able to do it more often before I installed 3.90 gears. Now with the 3.90 gears installed, I can hardly make the tires chirp at all - wierd
Old Mar 14, 2005 | 12:39 PM
THRUST_'s Avatar
did you have it tuned when you put the new gears in?
Old Mar 14, 2005 | 12:43 PM
96vert's Avatar
I don't seem to have a problem in my auto. I just put the loud pedal to the floor quickly and hope for the best :-)
You might benefit from a chip tune (SCT or diablo tuner) to make the "drive by wire" more responsive. That would allow you to fully open the throttle-body more quickly, thereby generating power faster.
I plan to do this in the near future on mine.
Old Mar 14, 2005 | 12:46 PM
I have a canned tune (SCT 91 octane) installed before the gear change.
I made changes to the tune to correct speedo.
I never turned off traction control.
How do you turn off traction control?
Old Mar 14, 2005 | 12:48 PM
Buck_Nekid's Avatar
There's a button over the radio marked "TCS". When you press it the "Off" light will come on.
Old Mar 14, 2005 | 12:49 PM
THRUST_'s Avatar
Button on the dash I think, I haven't drivin one
Old Mar 14, 2005 | 01:08 PM
Will the car remember your TCS preference or does it default to on whenever you start your car?
Old Mar 14, 2005 | 01:16 PM
HOTLAP's Avatar
The TCS defaults to "on" every time you start the car...back when I had my '00GT - there was an aftermarket switch available that switched the preference so the TCS defaulted to off - and you had to select it when you wanted it active......LB you should be seeing a light go off every time the TCS system kicks in...have you seen that or felt the car sort of "power down" when you floor it - that's the TCS.
Old Mar 14, 2005 | 01:27 PM
96vert's Avatar
Well, that will do it too - the TCS system will allow you to chirp your tires but that's about it.
Hit the TCS button and give it a shot.
Old Mar 14, 2005 | 01:55 PM
acadian's Avatar
I have no problem either. I even chirped the tires going from first to second... and yes I have an auto. Try turning the TC off and slam the accelerator. It will brun a little rubber. And you can always power brake to about 2000 rpm, and then let her go.
Old Mar 14, 2005 | 02:12 PM
-FROG-'s Avatar
lol!
jim010
Jun 24, 2024 04:23 PM
yabutt
Oct 23, 2015 01:05 PM
CoyotePremium13
Sep 23, 2015 06:45 PM
DrVet
Sep 23, 2015 01:48 PM
Fernando.4ohh
Sep 10, 2015 03:35 PM
