breathers/catch can installed
Old Jan 19, 2008 | 04:16 PM
OKLACOP's Avatar
Just had the breathers and catch can installed. Hopefully the breathers on the valve covers will eliminate any pressure problems. The catch can is to catch the small amount of transmission fluid that comes out of the blow off valve when I romp on it. It has a small breather on it as well. Any of you all with autos that are going with a supercharger are going to need this. This particular one is from Jeggs.
Attached Thumbnails breathers/catch can installed-venomventsicupgrade-013.jpg   breathers/catch can installed-venomventsicupgrade-014.jpg   breathers/catch can installed-venomventsicupgrade-015.jpg
Old Jan 19, 2008 | 04:29 PM
tmcolegr's Avatar
Question about your trans. catch can:
Why didn't you choose a catch can with the inlet in the bottom of the can? That way when the trans purges into the can, the fluid can then run back into the trans. and the level remains constant. Looks like your catch can will have to be drained and eventually the trans topped off with fluid.
Old Jan 19, 2008 | 06:15 PM
OKLACOP's Avatar
It will have to be drained from time to time. To be honest with you I just chose this one because it was small, black in color (so it didn't stand out under the hood) and the price was right. The amount of fluid that the can will catch will be maybe a tablespoon full in a years time. I'll have the fluid checked at regular intervals.
Old Jan 21, 2008 | 01:52 AM
mvon919's Avatar
Have you checked your AFR after this?? There's tons of unmetered air going into combustion now, bypassing MAF... This is not something that I'd recommend to do.. .especially if s/c'd or turbo.
Old Jan 21, 2008 | 03:34 AM
tmcolegr's Avatar
Please explain how there is "tons" of unmetered air entering after the MAF? Looks to me like he has completely/properly eliminated the PCV and capped off both ports which previously went to the PCV.
Old Jan 21, 2008 | 03:48 AM
302svt's Avatar
They look great. What size and brand of breathers did you use?
Old Jan 21, 2008 | 07:46 AM
OKLACOP's Avatar
They are capped and PCV is bypassed.
They are airaid brand and are 5/8"
Old May 20, 2008 | 08:59 PM
OKLACOP's Avatar
Hey guys.........Just revisited this post to update you on an issue. I was getting serious fumes in the car as a result of the breathers. It was almost like a bad exhaust leak. The breathers were removed and PCV stuff was put back together. No more fumes!!!!!! Now it's time for the air/oil separator. Hopefully this will be the end of this issue. Just wanted to pass along the breather issues. I now have two breathers for sale if anyone is interested.
Old May 21, 2008 | 10:30 AM
Commbubba19's Avatar
Yeah, could have told ya that. Plus, under hard cornering, oil will poor out of the breathers.
Run a catch can on the PCV system if that's something you're that worried about.
Old May 21, 2008 | 12:56 PM
OKLACOP's Avatar
The smell was killin us.....my wife refused to ride in it until I got it fixed......I couldn't blame her, it gave me one hell of a headache as well!
Old May 22, 2008 | 07:57 AM
one option is instead of running breathers, get some rubber hose that will fit over the PCV and route it down to the bottom of the car. that will rid you of the smell issue and still allow you to remove the PCV system.
bad thing is you'll have oil drips.
Old May 22, 2008 | 09:42 AM
OKLACOP's Avatar
I'm gonna end up getting another catch can I guess.
Old May 22, 2008 | 10:33 PM
mikeelia's Avatar
I believe there was a whole thread on a can setup for this a while back...
Mike E
Old May 23, 2008 | 08:52 PM
OKLACOP's Avatar
This was an old thread I started a while back (note the date on post #1). I just thought I'd revisit it w/ an update.
Old May 25, 2008 | 01:27 PM
MLC40's Avatar
How much for the breathers?
14Glassback
Oct 4, 2015 08:52 AM
Sep 10, 2015 12:44 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
