Brakes no longer squeek
I got my car back from the tune shop on Sunday, and the brakes are no longer squeaking. We abused the heck out of them, and had to stop to let them cool off. Ever since then they quit squeaking. I hope this resolves the issue for good.
It seems to be getting louder.
I'm taking it into the dealer tommorow.
Might explain why this issue hasn't developed for me. I've spent some time drivin it on twisty mountain switchbacks going downhill taking it to it's limit. Lot's of brakes, lot's of acceleration. No brake sqweak.
It's also been noted by somebody else that it goes away after awhile once the brakes are broken in so to speak.
Im at 3500 miles and mine still squeak. Im taking my car in Friday for the popping noise in the front, to have the bolts on the bell housing installed, and to have the brakes checked.
I have used mine pretty hard and it hasn't gone away, in fact its actually getting louder.
2000 Miles and has squeeked from mile 15. :bang:
Found two links for Bedding In:
www.stoptech.com/whitepapers/bedintheory.htm
http://www.zeckhausen.com/bedding_in_brakes.htm
Originally posted by Dan@February 15, 2005, 5:44 PM
I have a feeling that this doesn't need to be done and that the sqeeking is due to the metallic material used in the pads.....but someone is welcome to try it and let us know if it helps....
I followed the procedure above for bedding in the brakes, and now my discs are a nice blue colour. My wheels really need a cleaning though.
I am hoping this will prevent the squealing problem some people reported. I did the same on my 91 Miata (modified), and it really helped to makes the brakes more responsive.
Originally posted by acadian@March 16, 2005, 4:52 PM
Mine squeaked from day one... well maybe like day 10... and I brought it to the dealer and had them replace the pads and now no squeaks.
Ian - mine have started to squeek on a "sometime" basis and I was curious....what did your dealer change to stop your squeeking....did they install the same pads new - or a different pad or what...I ask because mine did not start squeeking until 2800 miles and just installing new pads may be a temp fix until you get more miles on them and they start up all over again.....has Ford acknowledged this issue and are they working on a fix for us?
Sep 8, 2015 10:45 AM
