Brake Modifications
I want to sign up for an SVTOA track event in May, but need to find brake upgrades first. Anyone know how much front OEM rotors cost? What kind of performance/track pads are available? I read somewhere that Porterfield was coming out with some soon. Any company make stainless steel brake lines? I don't want to go to the track with my stock brakes, so I need to do something soon or not go at all. The OEM brakes will be toast after a few laps.
Powerslot now has front and rear rotors for the '05 V6 and GT. They are slotted, not drilled... and run about a hundred a piece.
Edit: And I know Hawk has performance brake pads too.
Ronaele is offering LIFETIME slotted and cross-drilled rotors. I saw their car in person at an event I went to this past weekend. I live in Tampa, they are out of Palm Harbor.
Ed is a really great guy, nice to talk to. He said they are still working on getting their parts / products available through tirerack.com and NAPA, not definite, but in the works.
Might I add that their car is even sicker in person. Looks great, they did a nice job. But their rotors can be seen at ronaelemustang.com - under parts section.
I believe he said they will run around $150.00 each. Much better than Steeda's, and they have a LIFETIME warranty.
http://www.porterfield-brakes.com/
How about brake fluid ? I always changed the brake fluid in my previous cars with motorcycle-specific Motul brake fluid so it wouldn't boil, as well as HP-Plus for track days. These pads were so noisy but got progressively quieter as they were getting hot.
As for brake fluid, the HD Ford fluid has a pretty high BP. Motul is good stuff too.
heres a pic of the steeda KVR brakes ![](http://www.steeda.com/store/images/brakes/KVR/thumb.jpg)
Crossed Drilled Discs offer an enhanced initial bite (more responsive, especially in wet weather) and greater heat dissipation (reduction in heat induced fade - "Brake Fade") as compared to O.E.M.
KVR Performance uses only the very best in components: 6061 T6 billet aluminum for the hats, directionally-vaned, American made racing discs for the rotors, and NAS aerospace grade hardware to mount the hats to the discs. Lighter than stock (4 lbs. less per rotor up front, 3 lbs. less out back; 14lbs. lighter total!), thus reducing rotating mass and increasing braking ability.
VELOCITY CHANNELS are machined by KVR into the hat assembly to allow for airflow onto the outboard face, equalizing inboard and outboard disc temperatures. These velocity channels allow extra ventilation to prevent heat soak when static (stopped after a lapping session or high temperature use). Every KVR disc is hand assembled and checked for lateral, radial run-out as well as surface finsh and overall balance ( 0.70 KG mm ). Direct fit - no modifications required to install.
Originally posted by charles@April 7, 2005, 2:25 PM
heres a pic of the steeda KVR brakes![](http://www.steeda.com/store/images/brakes/KVR/thumb.jpg)
Antigini-GT/CS
10/5/15 09:43 AM
