BMR Relocation Brackets???
Hi everyone. I am planning on doing my Eibach Pro springs, LCA's, and relocation brackets pretty soon here once the weather gets nice. Which hole should I be using on the relocation brackets. TacoBill's write up says up to an inch drop you can use the top hole, but Eibach Pro's are around 1.4inch from what I hear. What is the benefit of using the lower hole? What are you guys/gals using out there?
Thanks!
Thanks!
I did the lower hole with my Eibach Pro Kit, but the car didn't handle near as well as it did before the brackets. I went up to the upper hole. The LCA's still angle down slightly (which is still good for straight line), but it handles a lot better.
Feb 10, 2017 07:12 PM
