BMR Adj Panhard
Old Jul 9, 2007 | 04:54 AM
AFChief's Avatar
BMR Adj Panhard
Noticed a few pics of others installs. Should the side with the adjust nut go on the left or the right? Instructions don't say. Looking at the grease fittings, one has a 90 degree fitting, the other is standard. Looking at the inteference on install, I decided the 90 degree needed to be on the left, putting the adjusting nut to the right. Does it matter?
Old Jul 9, 2007 | 07:40 AM
scramblr's Avatar
Hmmm, it's been a year, but I think I remember the instructions stating on the passenger side. That's how I installed mine, however, I've seen pics with it the other way as well. BMRs pics also show the adj nuts on the passenger side.
Old Jul 9, 2007 | 07:43 AM
RobK's Avatar
Mine's on the passenger side.
Old Jul 9, 2007 | 07:47 AM
MooStang05gt's Avatar
The adjustment should be on the right (passenger) side of the car. You have it installed correctly.
I just looked a my BMR installation instructions, they say put the grease fittings down, so it doesn't matter which side the adjuster is on, left or right.
Bobby M.
Old Jul 9, 2007 | 08:27 AM
biznazion's Avatar
I just installed mine and had the same question. The only way you can get a grease gun on the drivers side is if the 90 degree fitting is there - putting the adjuster on the passenger side.
Old Jul 9, 2007 | 08:59 AM
howarmat's Avatar
+1 to all of the above
Old Jul 9, 2007 | 09:57 AM
ren274u's Avatar
same here passenger side
Old Jul 9, 2007 | 11:09 AM
MTAS's Avatar
Mine's on the driver's side, has been since day one (more than 2 years ago). No problems other than it came loose once. Some Loctite fixed that.
Old Jul 9, 2007 | 07:28 PM
AFChief's Avatar
Thanks. I finally found the pic on the BMR site.
Thanks fro the tip on the Loc tite too. I cranked pretty hard on the bolts, but will check it out.
Airborne42
Sep 25, 2015 05:14 PM
robjh22
Sep 8, 2015 12:31 PM
ToddMcF2002
'10-14 Exterior Modifications
17
Aug 3, 2015 07:42 PM
Kgilly
Jul 9, 2015 01:47 PM
