Benefits of Sway Bar Upgrades?
Old Aug 21, 2006 | 12:50 PM
GRAYPNY's Avatar
I have the Roush rear springs approx. 1 inch drop and would like a little better handling in corners. I am thinking that replacing the sway bars would give me better handling without going the shocks, springs, relocation brackets route.
Can anyone with a GT give me some feedback on just doing the sway bar change? Also there are different manufacturers and I was thniking either Eibach, Steeda or Ford Racing.
Old Aug 21, 2006 | 03:10 PM
94tbird's Avatar
i did the whole FRPP kit (shocks, struts, springs and swaybars) it is a night and day difference.
Old Aug 21, 2006 | 06:21 PM
ponyent's Avatar
I also have the FRPP handling kit as well as a Fays2 Watts Link and my '07 GT corners like it is on rails! The only downside is sacraficing the ride quality a little bit.
I have heard people recommend using suspension components that are designed to be used together so there is no mismatching. Made sense to me.
Old Aug 21, 2006 | 06:25 PM
Boltzman's Avatar
Anybody have Tokico D spec adjustable shocks with their lowering springs? I want to lower mine but don't want to sacrifice ride quality. Will these help??
Old Aug 21, 2006 | 06:32 PM
GRAYPNY's Avatar
Does anyone have just aftermarket sways bars?
Old Aug 21, 2006 | 06:57 PM
Import-Slaya's Avatar
Absolutely. You can even adjust their settings so they are even plusher than stock (if you want... ).
Old Aug 21, 2006 | 07:49 PM
eat.the.rude's Avatar
I just installed the FRPP anti-roll bar kit (M-5490-A) on my '06 GT this weekend. It definitely tightens up the steering feel and cuts down on the body roll compared to the stock parts. Before the install the car tended to " plough" a bit going into ramps and tight curves (understeer) which drove me nuts, especially considering my previous car was a Mini Cooper S that really sliced and diced corners. With the new bars the steering feel is very close to neutral - to me it's how the car should have come from the factory. I started with the front sway bar in the middle adjustment (3 positions available) and will drive it a week or two before trying another position but it will probably end up where it is now. The install itself is very easy and can be done with the car on ramps with the wheels on. The rear bar install is simple and the front bar is ridiculously easy to replace.
When I researched the FRPP kit my findings indicated that the bars are made by Eibach for FRPP. The urethane bushings in the kit are from Energy Suspension, their instructions were in the frt bar bushings/clamp kit. An added benefit to the FRPP kit is the bushing caps have zerc fittings to make greasing the bar bushings fast and easy.
My only other suspension mods are the FRPP strut tower brace and a Steeda G-Trac brace. I decided against lowering the vehicle because I didn't want to worry about ride harshness, speed bumps, opening doors next to high curbs, etc. Like you I also didn't want to deal with adjustable panhard bars, relocation brackets, etc., etc. Replacing the sway bars made a noticeable improvement in the handling and if it's made the ride any harsher it's negligible. The sway bar upgrade gets a from me.
Old Aug 21, 2006 | 07:53 PM
slowjoe24's Avatar
Thanks............Good Info!
Old Aug 21, 2006 | 09:12 PM
GRAYPNY's Avatar
Now that's what I was looking for! Thank you~
Old Aug 21, 2006 | 09:48 PM
Boltzman's Avatar
Sorry Rich.My bad
Old Aug 21, 2006 | 10:25 PM
GRAYPNY's Avatar
LOL, it's OK I got the info I was looking for!
Old Aug 22, 2006 | 01:52 PM
Rondosa's Avatar
Meet Krissy, Our Star Racer
Dude, i just installed them last friday (had the eibachs since last october) and i cannot BELIEVE that i waited this long. i HATED the way the car handled with just springs...talk about sacrificing ride quality, just springs was the WORST idea i've ever had (i knew it was wrong to do but i just wanted them in and didn't have money for the d-specs just then).
the car rides like butter now...i love it. and while i was in there, i cranked the upper link to the sway bar (front) down and the creaking/bumping noise is totally gone.
best money i've spent on the car so far.
people, i don't understand how you drive the car with only rear springs in, or worse, cut spring.
Old Aug 22, 2006 | 07:24 PM
Boltzman's Avatar
may I ask the cost of your dspecs? also,you get to update your sig!!
Old Aug 22, 2006 | 09:05 PM
Rondosa's Avatar
hey good point!!
i bought the d-specs from shox.com and they were $591 and free shipping within the US. No tax if you don't live in Cali. either. They are worth every penny...plus I installed them myself (with help from a certified mechanic). you can do it in about two hours with a lift...i love air tools.
k
Old Aug 22, 2006 | 09:19 PM
tkogt's Avatar
the frpp bars with the front bar set in the center were worth 3 seconds at the track but when i upped to the full frpp setup the lap times got interesting!
then i put the front bar in the "stiff" setting and the lap times dropped by an other 1.5 seconds!!!
do the full set up and dont look back
the look is killer and the lateral g's are in the 1.25+ range
jay
GeoWett
Sep 30, 2015 06:40 AM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
