BBR lca's
BBR lca's
any one using these or know about the quality?
http://www.ebay.com/itm/251135175734...84.m1438.l2649
I myself installed J&M LCA's and they're pretty good so far. My only caution with aluminum LCA's is that they don't flex much and I'd worry that they can snap. I'd save my money and go with steel. Sure they're a bit heavier but also less expensive.
They are pretty...but...not adjustable. The rubber bushings shouldn't be a problem...unless you are racing and have a LOT of power...in which case you wouldn't want these anyway...you would want solid rod ends on steel rods.
But, the fact that they aren't adjustable bothers me. If you lower your car at all you need to adjust the LCAs to correct the pinion angle.
I appreciate the skooling ... I guess I like complete control. I originally used GT500 suspension that left my 1-piece driveshaft from The Driveshaft Shop in improper alignment with my pinion. I found a good deal on some adjustble LCAs with solid rod ends...so I bought and installed them. The side to side (dual) adjustment was a cinch....as was he correction to the pinion angle. However!...I hated the LCAs. They had had solid rod ends on both ends and for street driving (although I am NOT a DD) the noise is terrible. I have now waiting for me to install a complete adjustable upper control arm, two new adjustable LCAs...all with rubber bushings. Also, I have an anti-squat bracket kit for the LCAs and an axle brace ... all vfrom Che
What was the deal with the angle they are set at.
angled up is better for what kind of driving?
set level is best for all around driving.
and angle downwards is better for what kind of driving??
