BBR lca's
Old Jan 10, 2014 | 06:19 PM
BBR lca's
any one using these or know about the quality?
http://www.ebay.com/itm/251135175734...84.m1438.l2649
Old Jan 19, 2014 | 12:13 AM
Gigantor's Avatar
I myself installed J&M LCA's and they're pretty good so far. My only caution with aluminum LCA's is that they don't flex much and I'd worry that they can snap. I'd save my money and go with steel. Sure they're a bit heavier but also less expensive.
Old Jan 24, 2014 | 06:20 AM
fdjizm's Avatar
I have the BBR LCA's very good quality, no issues, it's been about a year.
Old Jan 24, 2014 | 10:28 AM
Thanks for the replies. Yea they look pretty beefy. I was wondering how the rubber bushings hold up.
Old Jan 25, 2014 | 09:48 AM
raetza's Avatar
They are pretty...but...not adjustable. The rubber bushings shouldn't be a problem...unless you are racing and have a LOT of power...in which case you wouldn't want these anyway...you would want solid rod ends on steel rods.
But, the fact that they aren't adjustable bothers me. If you lower your car at all you need to adjust the LCAs to correct the pinion angle.
Old Jan 25, 2014 | 12:15 PM
fdjizm's Avatar
In the S197 it's more common and easier to adjust the pinion angle with an adjustable upper control arm instead of the pain of messing with two lower control arms.
Old Jan 25, 2014 | 04:53 PM
also with a lot of springs out there no pinion adjustment is needed.
Old Jan 31, 2014 | 02:19 PM
Cavero's Avatar
I'd reco getting an adjustable upper control arm to do that. Two adjustable arms can be a PITA to keep the same length if you're adjusting them on the car. Plus getting the UCA will help control axle hop even more on top of what the LCAs do for you.
Old Feb 2, 2014 | 07:44 PM
raetza's Avatar
I appreciate the skooling ... I guess I like complete control. I originally used GT500 suspension that left my 1-piece driveshaft from The Driveshaft Shop in improper alignment with my pinion. I found a good deal on some adjustble LCAs with solid rod ends...so I bought and installed them. The side to side (dual) adjustment was a cinch....as was he correction to the pinion angle. However!...I hated the LCAs. They had had solid rod ends on both ends and for street driving (although I am NOT a DD) the noise is terrible. I have now waiting for me to install a complete adjustable upper control arm, two new adjustable LCAs...all with rubber bushings. Also, I have an anti-squat bracket kit for the LCAs and an axle brace ... all vfrom Che
Old Aug 8, 2014 | 07:19 PM
Well 8 months later I finaly picked a set of these up. Nice heavy duty stuff. I don't think you can beat them at right around 200 bucks. They wouldn't work with the home made relow brackets I made.
What was the deal with the angle they are set at.
angled up is better for what kind of driving?
set level is best for all around driving.
and angle downwards is better for what kind of driving??
DrVet
Sep 23, 2015 01:48 PM
SpeedyJoe
18
Aug 23, 2015 02:42 PM
JohnnyZ
Aftermarket 2005+ Mustangs
13
Jan 15, 2006 08:42 PM
The long rider
Dec 5, 2005 06:31 AM
JohnnyZ
70
Oct 7, 2005 11:03 PM
