Bassani and check engine light
Old Apr 26, 2005 | 06:52 AM
I8URVTEC's Avatar
Will changing the stock cats to the Bassani cats cause the check engine light to go on?
Old Apr 26, 2005 | 07:45 AM
subzero05's Avatar
probably..If oyu are going to change out the cats I would recommend a tune to accomodate that
Old Apr 26, 2005 | 09:10 AM
I8URVTEC's Avatar
Who has a good tune for that? Diablo? When I do that tune would it turn off the check engine light? Also, I would have to put the stock cats back on before inspections...do you know if that would turn the check engine light back off if I didn't turn it off with a tune?
Old Apr 26, 2005 | 09:42 AM
porsche's Avatar
you will be running lean withit first off i would get a diablo to tune !
Mine went to a 13.7 with a x pipe hi flow cats!
Old Apr 26, 2005 | 09:44 AM
I8URVTEC's Avatar
The diablo tune fixed it from running lean? Did the check engine light come on for you and if so did the diablo tune turn the light off?
Old Apr 26, 2005 | 10:51 AM
porsche's Avatar
No cel light came on ,but the diablo can turn it off or re-set and read codes.
Old Apr 26, 2005 | 11:39 AM
I8URVTEC's Avatar
I called up Bassani and they told me that they have not experienced the cats causing the check engine light to come on. They also said that the system did not require a tune but it could be done. The last thing they told me which I did not know until now was that although the cats are not smog legal in NY, new cars or cars bought this year are exempt from emissions testing for 5 years when being inspected. Anyone else hear this?
Old Apr 26, 2005 | 12:01 PM
Kluski's Avatar
I could only dream. I know in Pittsburgh, if you drive less than 5,000 miles (??) between inspections, you are emmisions exempt.
Old Apr 27, 2005 | 07:58 AM
I8URVTEC's Avatar
I did some further research myself on the DMV website and it says that new cars are exempt from emissions testing if they are within two years of the model year of the car. I guess that would make me exempt until 2007. That's not as good as being exempt for 5 years but I'll take it.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
