Automatic Transmission: How much Power?
Hey all, first post. For curiosity sake, how much aftermarket power can be safely added to a GT with an auto tranny? I remember reading that someone had mentioned a 30% rule. With that in mind a 90HP increase would max you out. I just read the specs on a Saleen and they sell the supercharged model with either tranny.
Also, how would one go about upgrading the auto tranny to reliablly handle more power? Thx.
I don't know about the rules for adding power to a trans, but this trans probably doesn't have any aftermarket heavy duty parts available for it. It also didn't start out as a heavy duty trans, being based on the C3, if I recall correctly. I share your concerns, as I have an auto on order, but question this trans' durability behind a V8.
An aux trans cooler would be the first mod I'd make to the car.
ROLL ON
Thanks guys,
Since I never seem to leave well enough alone when it comes to cars. I'm afraid that if i order the auto, I'll be trading it in for a manual later. I've been watching this forum to see what works and what doesn't. So guess we'll just watch and see.
Typically, components in a car are designed with a 10-20% extra margin.
So I'd speculate the transmission would work indefinitely at 330-360hp (at the crank). That is not to say it will not perform fine at higher levels, but I would not say "indefinitely."
Since this tranny is a fleet tranny used in the T-Bird and LS, it may actually have been over-designed even more, in anticipation of using it in beefier vehicles.
Rando
8/25/21 11:12 AM
