Automatic trans problems
Hi any input would be appreciated. I have a 05 GT convertible with 1500 miles. Has done this 3 times. When stopped for a light when you press on the gas revs go up and car acts like it is neutral. Apply brakes wait a moment and car drives normally. Computer problem or mechanical problem? Will any code be set? Thanks
Wilson, my auto has never done this and you should take it back to the dealer right away. Maybe it's low on fluid, but only the dealer can check the level as there is no dip stick on the 05. Take it back.
http://forums.bradbarnett.net/index.php?sh...&hl=stomp&st=20
Could be the nature of this tranny - I had the same one in my '01LS for years and while it was duarable and I had no "major" issues - it did have small "nits" that were irritating. Sometimes the hesitation at start then bang into gear, sometimes at freeway speeds if I would let off the throttle then reapply it would bang for some reason...IMO....these newer trannys are too complex and think too much - which causes hesitations at certain shift decision points. Mine was eventually reflashed which helped some - but always was a bit finiky - just the nature of the beast.
Hello everyone and thanks to all that replied. I took the Gt to the dealer today and they checked the fluid level which was fine and found no codes. The service manager and I did stop and go in a residental area for 45 minutes and could not duplicate the problem. So we will start a log everytime it does it and note miles weather conditions etc. And see what develops.
Rando
8/25/21 11:12 AM
