Aluminum Flywheel
Old May 2, 2006 | 02:19 PM
Dubai's Avatar
i want to get a aluminum flywheel but i dont really know what brand to go with.
anyone installed one yet?
and what should i expect from it. thanks..
Old May 2, 2006 | 03:14 PM
70MACH1OWNER's Avatar
<div class='quotetop'>QUOTE(Dubai @ May 2, 2006, 3:22 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Mohd,
All you will gain from an aluminum flywheel is a little less rotating mass which will allow your engine to rev a little quicker. Had one on a 96 Cobra and determined the little bit of gain was not worth the money for a street driven car. You can gain the same thing for less bucks going to an aluminum driveshaft. JMHO.
Scott [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
Old May 2, 2006 | 08:33 PM
dhof303's Avatar
If you change the flywheel to an aluminum it will allow you to run a dual friction clutch without shims and make a better setup for street/strip or a power adder down the road.
Derek
Old May 2, 2006 | 09:18 PM
dustindu4's Avatar
9 is not my lucky number.
Does the new Centerforce D/F clutch kit require shims with the stock flywheel? If so does it come with all the parts needed?
Old May 3, 2006 | 06:20 AM
dhof303's Avatar
<div class='quotetop'>QUOTE(dustindu4 @ May 2, 2006, 10:21 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I am checking into this, currently I believe if you go with an aftermarket flywheel that takes up the space of the area normally needed for shims. I could be wrong but I will check.
Derek
Old May 3, 2006 | 11:13 AM
jp's performance's Avatar
<div class='quotetop'>QUOTE(dhof303 @ May 3, 2006, 6:23 AM) Quoted post</div><div class='quotemain'>
Derek
[/b][/quote]if you buy a specific 05-06 flywheel no need for shims,just fixed mine had to use 2 shims and it works great,i have the stock flywheel with the centerforce df clutch grabs good hope to make it to the track this weekend. [img]style_emoticons/<#EMO_DIR#>/icon_mrgreen.gif[/img]
Old May 4, 2006 | 12:34 AM
nonsensez9's Avatar
How well do the Hays flywheels and clutches rate?
Old May 4, 2006 | 06:10 PM
<div class='quotetop'>QUOTE(nonsensez9 @ May 4, 2006, 12:37 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]hayes flywheels are nice rpmoutlet sells them for the 05-06 gt for$390.00 and it fits 10.5-11.0 inch clutches,weights 15 pounds.
Old May 6, 2006 | 06:48 PM
thump_rrr's Avatar
<div class='quotetop'>QUOTE(jp's performance @ May 4, 2006, 8:13 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I got the Fidanza Aluminum Flywheel which is 12 LBS for $319.00 shipped
I also got the Centerforce Dual Friction Clutch DF611679 for $261.88 shipped.
I got them both from http://byunspeed.com/
Fast service and great prices. He's not a stang guy so you're better off knowing exactly what you need.
Old May 10, 2006 | 06:26 AM
BillR's Avatar
Years ago, I added an aluminum flywheel on and RX-7 that I build to the max (I used to prey on 5.0 Mustangs back then and whoop thier azz bad), put one on, I am sure you will be VERY happy with the results!!
May 3, 2026 05:42 AM
dblhelx
Oct 6, 2015 08:08 PM
