All with shop manuals on DVD. Come in plz.
Old 1/16/06, 01:06 PM
blackened's Avatar
Can anyone tell me the backlash spec's 05GT's 8.8" rear end w/ 3:55's? Can ya do one better and e-mail me a PDF of that section?
I assume that the lash should be set the same as before even with a shorter gear like a 4:10. My FRPP 4:10's are whining and the shop AND I are reluctant to put it back up on the lift for an entire day. I trust these guys but wanted to know what the factory specs are to compare to their setting.
Thanks in advance.
Old 1/16/06, 01:35 PM
FordRacing's Avatar
Here's the spec's Gear ratio will have no effect on the backlash setting. THe PDF of the spec is below.
Clearance, Tolerance and Adjustments
Maximum differential case runout 0.076 mm (0.003 in)
Differential side gear thrust washer thickness 0.762-0.813 mm (0.030-0.032 in)
Differential pinion gear thrust washer thickness 0.762-0.813 mm (0.030-0.032 in)
Maximum axle shaft end play 0.762 mm (0.030 in)
Pinion bearing preload (used pinion bearings) 0.9-1.5 Nm (8-14 lb-in)
Pinion bearing preload (new pinion bearings) 1.8-3.3 Nm (16-29 lb-in)
Ring gear backlash 0.203-0.381 mm (0.008-0.015 in) [0.305-0.381 mm (0.012-0.015 in) preferred]
Variation between teeth maximum backlash 0.102 mm (0.004 in)
Available drive pinion bearing adjustment shim in steps of 0.25 mm (0.010 in) 0.254 mm (0.010 in) - 0.965 mm (0.038 in)
Pinion flange runout 0.25 mm (0.010 in) T.I.R.
[attachmentid=43042]
Old 1/16/06, 01:38 PM
9 is not my lucky number.
dustindu4's Avatar
I can send you the whole pdf for replacing the rear end if you PM me your email
Old 1/16/06, 02:49 PM
blackened's Avatar
PM'd
Old 1/17/06, 01:53 PM
I talk to cones.
softbatch's Avatar
Speaking of this has anyone got the shop manual stuff on changing Caster and toe settings? I already got camber from the issues section.
James
softbatch7236@gmail.com
Old 1/17/06, 03:41 PM
dustindu4's Avatar
caster and toe? what part of the car does that come from?
Old 1/17/06, 04:23 PM
SixtySix's Avatar
Front end alignment settings Dustin
Old 1/17/06, 05:16 PM
dustindu4's Avatar
Oh, I thought you meant camel toe
Old 1/17/06, 05:27 PM
RPM
RPM's Avatar
LOL
Old 1/17/06, 07:40 PM
FordRacing's Avatar
James
Do a search for the spec's I posted them awhile back.
As for changing caster there is no adjustment for this. (at least from the factory)
Old 1/17/06, 07:42 PM
davids2toys's Avatar
Old 1/17/06, 08:24 PM
I talk to cones.
softbatch's Avatar
Originally posted by dustindu4+January 17, 2006, 6:19 PM--><div class='quotetop'>QUOTE(dustindu4 @ January 17, 2006, 6:19 PM)</div><div class='quotemain'>Oh, I thought you meant camel toe
[/b]
Thanks Dustin that's exactly what I needed.
<!--QuoteBegin-FordRacing
@January 17, 2006, 8:43 PM
[/quote]
I searched your username for alignment, caster, and toe but couldn't find anything on it. I got the info from Dustin in the PDFs though.
Now I just need to decide if I want to change my toe settings before events.
Old 1/17/06, 09:01 PM
dustindu4's Avatar
a great camber and toe reference
www.cameltoe.org
Old 1/17/06, 09:35 PM
emperorjordan's Avatar
One thing to note when setting the backlash... when you torque the two bearing caps down, the backlash measure is slightly different then when they are only partially tight.... So be sure you torque them down to spec before measuring it. With my 4.30s I ended up with just over .008" all around.
trackpack13gt
7/25/17 05:29 PM
wallace
3/29/16 10:09 AM
mx5jhb
9/30/15 04:44 PM
Kalel08
9/29/15 03:06 PM
GLOCKer
9/28/15 05:20 PM
Quick Reply: All with shop manuals on DVD. Come in plz.
