Air Bag for single rear springs.
Old Aug 3, 2007 | 10:49 PM
Sharky's Avatar
Someone in here mentioned that he uses an airbag for one of the rear springs.
I believe he pumps it up at the track and deflates it when driving around town.
1. Who was that guy, and would he mind giving out more info??
2. Would this idea work for a Vert as the rear springs are not the exact same as a Coupe?
3. What airbag (pn) do you use?
THX,
Shark
Old Aug 4, 2007 | 12:03 AM
theedge67's Avatar
Why would this be a good idea to use on only one spring??
Old Aug 4, 2007 | 10:49 AM
Sharky's Avatar
This is a kit Eibach sells for our cars.
The single airbag helps plant the one tire.
Someone on here was talking about doing this months ago.
Old Aug 4, 2007 | 12:19 PM
theedge67's Avatar
I'm wondering how much this would help, given the fact the GT's have a Limited Slip rear end. I've never had any problem with only one wheel spinning. Any time I spin the tires, it leaves a nice even set of 2 black marks on the pavement
Old Aug 4, 2007 | 01:37 PM
RedDragon777's Avatar
the thing is even with both tires going, the car seems to torque to one side, so the air bag helps keep the right side of the car from going too low during launch so the car is more leveled and more power goes to both wheels
Old Aug 4, 2007 | 02:39 PM
GT John's Avatar
Originally Posted by RedDragon777
the thing is even with both tires going, the car seems to torque to one side, so the air bag helps keep the right wide of the car from going too low during launch so the car is more leveled and more power goes to both wheels
The air bag is installed in the rear passenger side coil spring. The pressure that you inflate it to is experimental.
Or, some guys that are running this setup will tell you what pressure to run at the strip to start with. You will have to adjust from there based on your own setup.
One guy I know is running a Fox Body at 800hp. He has his inflated to 80lbs. Runs in the high 8's and low 9's.
Old Aug 4, 2007 | 02:49 PM
yeah the right side, alot of my friends use this but some of them do not inflate it enough and still torque to the passanger side
Old Aug 4, 2007 | 03:51 PM
don_w's Avatar
I'm one of those guys who is looking to do something along these lines. Even with all the suspension work I've done, I still get some roll to the passenger side on the launch. It's not nearly as bad as it was before, but it's still there. Here are a couple vids from last night. You can see the right rear drop on the launch.
Body Roll Example #1
Body Roll Example #2
Right now, I'm looking at three potential options:
1. Install the BMR Xtreme Anti-Roll Bar.
2. Find a stiffer spring for the right rear (but it has to be a non-lowering spring).
3. Go to a right side airbag as discussed in this thread.
p.s., Anyone know if the Eibach kit mentioned above uses lowering springs or not??? I do not want to lower my car.
Old Aug 4, 2007 | 07:58 PM
GT John's Avatar
Man.............I love watching your videos
I'd do the air bag first............cheap.........easy to install.........adjustable and it should work. Looks like your dropping about 3 or 4 inches on the rear passenger side.
The guys were working on another race car at the shop today (1500hp), full rail frame. The were testing the adjustable rear shocks and adjusting them just buy turning a **** on the bottom of the shock. Pretty effective, I saw the brand name but not well enough to remember it.
I'll pay a little more attention next Saturday.
Old Aug 4, 2007 | 09:03 PM
don_w's Avatar
Thanks John. I have adjustable shocks already. The right one is set at full firm... the left is 3 clicks softer.
Old Aug 4, 2007 | 10:45 PM
Sharky's Avatar
The kit does say that it lowers the car.
Someone in here recommended the airbag awhile back.
I thought it was you Don.
He even recommended a part:
http://store.summitracing.com/partde...0&autoview=sku
But as I have a vert, I don't believe this will fit my springs??
Old Aug 9, 2007 | 03:11 PM
Chilliwack 42's Avatar
I have these on my 69 Chevelle. You can preload the passenger side spring to prevent wheel hop and to help launch your vehicle straight.
Fords4Ever
Oct 30, 2015 09:07 PM
dblhelx
Oct 6, 2015 08:08 PM
DrisStang
Sep 14, 2015 06:20 PM
Sep 8, 2015 10:45 AM
