Aftermarket wheels and rotor clips
Old Jul 29, 2007 | 01:53 PM
JonW's Avatar
When I had my aftermarket wheels installed, they did a great job of balancing them out, but I still had a little bit of side-to-side steering wheel shimmy at 65+ mph. I read on here somewhere about removing the rotor clips, so I did that this morning. Now ALL my shimmy is gone.
If you're running aftermarket wheels and have a shimmy, you need to do this mod. Just pull the wheels off, pry off the metal clip that is slipped over one lug stud on each rotor, and you're good to go.
Old Jul 29, 2007 | 04:17 PM
jwgroovin's Avatar
If you're running aftermarket wheels and have a shimmy, you need to do this mod. Just pull the wheels off, pry off the metal clip that is slipped over one lug stud on each wheel, and you're good to go.
Man, I went through hell two years ago with this issue. Brand new 18" AFS wheels, and it took us hours to figure the rotor clip problem out. I must have rebalanced and realigned my car twice in a day (my son works in a shop).
John
Old Jul 29, 2007 | 04:43 PM
70MACH1OWNER's Avatar
Don't your aftermarket wheels have c'bores that clear the factory clips???? They should!!!!
Scott
Old Jul 29, 2007 | 04:46 PM
blkstang06's Avatar
John
Yep! some aftermarket wheels come counter bored for the clips and some don't..........Mine did! I still removed the clips..
Old Jul 29, 2007 | 08:22 PM
RobK's Avatar
Scott
Apparently not if he had the shimmy. The clips aren't necessary anyway. They're only on there to hold the rotors tight during assembly. Some wheels do and some don't. My BBS wheels do, but even BBS suggests on their website that the clips be removed.
Old Jul 29, 2007 | 08:26 PM
sound wave's Avatar
never heard about this issue before. thanks for the post jonw.
Old Aug 7, 2007 | 08:16 PM
Fryguy's Avatar
I took my clips off the other day after reading a few other posts on here.
Fixed my problem...
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
Jul 8, 2016 08:53 AM
FromZto5
75
Oct 5, 2015 02:27 PM
M3hunter
Sep 10, 2015 09:26 AM
earl610
Sep 6, 2015 05:48 PM
