Advise prior to fitting parts please.
Old 1/29/08 | 09:21 AM
Eduardo de Sousa's Avatar
Hi,
I am looking to fit in my 05GT M/T next month parts that i am receiving from US.
. MGW shifter
. Big 355 Brembo brakes
. Tokico D specs
.Steeda strut brace.
Having to drive 5 hours away to a specialised US automotive garage here in UK, is there any advise apart from not forgeting to take the parts with me that you suggest i should make sure it is done on those particular items ,has do not want to have to drive back all that way for any changes. (any warnings?)
They recon they would have all those parts fitted in less than 5 hours.
(Steve Austin as mechanic ?)
Thanks for your help.
(PS. i have got zenneti 5's 20" so clearence ok for brakes)
Eduardo.
Old 1/29/08 | 02:14 PM
2kanchoo's Avatar
Originally Posted by Eduardo de Sousa
Hi,
. MGW shifter
. Tokico D specs
Eduardo.
With those big wheels the brakes shouldn't be a problem, the strut tower brace is a straight bolt on, and the d-specs are a straight swap out. Which handle did you get with the MGW? Cause only 1 will fit the stock shifter ****, and they can come with that or one that fits the normal threading of *****. (pre 2005 stangs etc)
I could see them doing it in 5 hours if they are really good. It would be the full 5 hours tho.
Old 1/29/08 | 04:39 PM
Thanks,
Thread for shifter is ok. Got a roush gear stick to fit too.
Eduardo. CAN'T WAIT!!!!!!!!!!!!!
Old 1/29/08 | 04:51 PM
MooStang05gt's Avatar
Thanks,
How did you get a Roush gear stick to fit the MGW??? Are you referring to a shift ****?
Your install should be pretty straight forward for a shop... You will love the MGW shifter... BTW did you get SS brake lines for your brake upgrade?
Bobby M.
Old 1/29/08 | 05:39 PM
Bobby M.
Hi, Sorry meant shift ****. The brakes come with some brake lines. Not sure they are SS ?
Thanks.
Eduardo.
awoychosky123
'10-14 Exterior Modifications
8/18/15 09:30 AM
tdf017
8/5/15 11:13 AM
Quick Reply: Advise prior to fitting parts please.
