? about Stock clutch performance
Old Jan 24, 2008 | 08:03 PM
ufnavy06's Avatar
My brother was talking to me about a week ago and he brought up a good point. When will my stock clutch fail? Like what kind of power numbers am I looking at before I should really consider replacing it? Or how long should the stock clutch last time/mileage wise? I drive the car moderately. Never really driven it 'hard.' Appreciate the input.
Old Jan 24, 2008 | 08:12 PM
RadBOSS's Avatar
Well apparently it will handle 475 RWHP. The killer is usually wear, because the more the disk wears, generally the less clamping force on it. At some point the clamping force will be insufficient to resist the torque and slipping will result, which causes even more wear and slippage. Results will vary widely depending a lot on the drivers technique. Stock it should be good 50k to 100k miles.
Old Jan 24, 2008 | 09:14 PM
karman's Avatar
Like anything else, it depends on how you use it.
My buddy got over 200k on his '89 GT and he is not light footed.
He has always driven V8 muscle cars though.
If you don't floor it until it is fully engaged it will last a good long time.
Old Jan 25, 2008 | 05:30 PM
RadBOSS's Avatar
Like minimize slippage starting off, and don't slip or ride the clutch on gear changes!!
Old Jan 26, 2008 | 12:57 PM
ufnavy06's Avatar
So the concensus is I'd be ok for a little while still. Good to know.
Old Jan 27, 2008 | 07:50 AM
Hatchman's Avatar
You should be good to go for a while. It's all on how you drive it. If you let it slip and smoke it one day (like I did pulling up onto some driveway ramps) it will glaze the surface, and then it will start slipping on you on hard shifts at WOT, like mine did. When I took it out, it still looked great, but I had trouble barking them in third, so it had to go. My fault though.
ssjbuu
Aug 28, 2015 08:55 AM
Mug-stang
Jul 31, 2015 10:25 PM
stewarts359
Jul 21, 2015 03:39 PM
Kgilly
Jul 9, 2015 01:47 PM
