Now what?
Old Jan 26, 2008 | 10:37 PM
rick06gtmustang's Avatar
Now what?
I have an 06 GT with ,delete plate,Steeda pullies,C&L intake ,Dougs 93 race tune,4.10 gears,BMR relocation brackets,upper control and lower control,Steada sport springs,Steeds Strut tower brace,5.0 shifter.. I had nitrous on my last stang ,it was fun,this one I think I will go turbo down the road.My question is what else can I do now? I read mixed reviews about 1 piece shafts.My car is 2 years old and I just clicked5,000 miles on her.She hooks pretty well with the current suspension.
Old Jan 26, 2008 | 11:46 PM
officespace56's Avatar
Nice set-up so far! I would go with some exhaust components next! Maybe some longtubes and an h-pipe would make the car sound mean
edit: nevermind, don't think LT's would work with a turbo. Maybe atleast an O/R H Pipe and some mufflers for now?
Old Jan 27, 2008 | 08:29 AM
Sorry
I have SLP LM2 on the car now,would I gain much by putting an off-road pipe on?I was thinking off road X with the stock mufflers back on??
Old Jan 27, 2008 | 09:37 AM
You probably wouldn't really feel much of a difference from what I hear, but its there. You will have a lot more noise either way
Old Jan 27, 2008 | 10:16 AM
2kanchoo's Avatar
You've got a d@mn nice setup there. What are you using for tires? Some sticky's on the back would definently help a lot. If you're going turbo I would suggest looking into everything you need for that. The list will be long that would be your best place to start. First pick a kit/how much power you want to make. Then make a list. Depending on the kit/power you might need better rear axles, tranny, etc etc. You've got most everything N/A covered.
Old Jan 27, 2008 | 10:22 AM
The Reverend's Avatar
1. Roll cage.
2. MT Drag radials.
3. K Member.
4. 14" Brakes.
Old Jan 27, 2008 | 11:08 AM
Very safe
I plan on doing a safe set up 425ish rwhp,I'm waiting on the new fuel set up that is in the works.It issupposeto be much more GT friendly than the Gt500 fuel pumps.I'm still running the stock zero's now,maybe a sticky would be a good chioce?
Old Jan 27, 2008 | 11:14 AM
DavidM's Avatar
Mezzier water pump
Old Jan 27, 2008 | 11:34 AM
Originally Posted by DavidM
Mezzier water pump
I don't know,but from what I"ve read withthe UDP the pump doesn't do much at all.Maybe someone who has one can chime in..thanks
Old Jan 27, 2008 | 11:38 AM
GRAYPNY's Avatar
Spydershaft!
