About the stock 2006 gt mustang transmission
Hope this helps:
TR-3650
Product Specifications
This five-speed overdrive transmission was developed using state-of-the-art technology and is designed for a wide range of cars and compact utility vehicles. Currenlty, the TREMEC TR-3650 is being used on the Ford Mustang GT and the BA Falcon.
Features:
If this information is insufficient to select a transmission model, please use this Light-Duty Application Engineering Form to supply your specifications. Our application engineers will be glad to customize and recommend a model for you.
To print or download a PDF version of this page, please click here or on the icon found above each table below.
CarBack to topTREMEC
Part Number
Weight
(lbs)
Torque Cap.
(lbs-ft)
GVW
(lbs)
Gear Ratio Chart
1st
2nd
3rd
4th
5th
6th
Rev
TR-3650 TCET1265
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-1 TCET2070
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
TR-3650-2 TCET1858
132
390
4,471
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-3 TCET1789
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-4 TCET1903
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-5 TCET1925
120
360
N/A
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-6 TCET1986
120
360
5,066
3.38
2.00
1.32
1.00
0.74
N/A
3.38
TR-3650 TCET5852
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
Copyright © 2005 Transmission Technologies Corporation.
All Rights Reserved.
TR-3650
Features:
- Center Distance - 85 mm
- Five-speed transmission with overdrive
- Two-wheel drive
- Advanced synchronizer design
- Optimized multi-rail shift linkage
- Improved shifter design
- Constant mesh, synchronized reverse
- End-load design with integral clutch housing
Part Number
Weight
(lbs)
Torque Cap.
(lbs-ft)
GVW
(lbs)
Gear Ratio Chart
1st
2nd
3rd
4th
5th
6th
Rev
TR-3650 TCET1265
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-1 TCET2070
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
TR-3650-2 TCET1858
132
390
4,471
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-3 TCET1789
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-4 TCET1903
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-5 TCET1925
120
360
N/A
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-6 TCET1986
120
360
5,066
3.38
2.00
1.32
1.00
0.74
N/A
3.38
TR-3650 TCET5852
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
The kenne bell test car experienced clutch slippage and failure at 499 ft lbs of torque.
Theres more in this pdf file. Interesting read. Recommended max rwhp is 450 as a safe limit.
http://www.kennebell.net/techinfo/fo...gtTechTips.pdf
