About the stock 2006 gt mustang transmission
Old May 26, 2006 | 05:35 PM
mustangfan123's Avatar
What is the most power the 2006 mustang gt stock trans. capable of handling?
Old May 26, 2006 | 06:44 PM
matko's Avatar
Hope this helps:
TR-3650
Product Specifications
This five-speed overdrive transmission was developed using state-of-the-art technology and is designed for a wide range of cars and compact utility vehicles. Currenlty, the TREMEC TR-3650 is being used on the Ford Mustang GT and the BA Falcon.
Features:
  • Center Distance - 85 mm
  • Five-speed transmission with overdrive
  • Two-wheel drive
  • Advanced synchronizer design
  • Optimized multi-rail shift linkage
  • Improved shifter design
  • Constant mesh, synchronized reverse
  • End-load design with integral clutch housing
How can we assist you with your specific requirements?
If this information is insufficient to select a transmission model, please use this
Light-Duty Application Engineering Form to supply your specifications. Our application engineers will be glad to customize and recommend a model for you.
To print or download a PDF version of this page, please click here or on the icon found above each table below.
CarBack to topTREMEC
Part Number
Weight
(lbs)
Torque Cap.
(lbs-ft)
GVW
(lbs)
Gear Ratio Chart
1st
2nd
3rd
4th
5th
6th
Rev
TR-3650 TCET1265
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-1 TCET2070
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
TR-3650-2 TCET1858
132
390
4,471
3.38
2.00
1.32
1.00
0.68
N/A
3.38
TR-3650-3 TCET1789
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-4 TCET1903
120
360
3,260
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-5 TCET1925
120
360
N/A
3.38
2.00
1.32
1.00
0.62
N/A
3.38
TR-3650-6 TCET1986
120
360
5,066
3.38
2.00
1.32
1.00
0.74
N/A
3.38
TR-3650 TCET5852
120
360
3,260
3.38
2.00
1.32
1.00
0.68
N/A
4.38
Copyright © 2005 Transmission Technologies Corporation.
All Rights Reserved.
Old May 26, 2006 | 06:46 PM
matko's Avatar
In a nutshell, 360 lb-ft. torque.
Old May 26, 2006 | 08:46 PM
could it handle 600hp?
Old May 26, 2006 | 08:53 PM
SVTJackl's Avatar
As long as the torque rating isn't exceeded....sure! But you'd have to rev the cr_p out of it to get there! LOL!
Probably not
Old May 26, 2006 | 09:24 PM
AJC's Avatar
AJC
The kenne bell test car experienced clutch slippage and failure at 499 ft lbs of torque.
Theres more in this pdf file. Interesting read. Recommended max rwhp is 450 as a safe limit.
http://www.kennebell.net/techinfo/fo...gtTechTips.pdf
Ecostang
Nov 3, 2022 08:50 PM
Burnhaven
V6 Performance Mods
Jul 23, 2015 11:57 AM
Burnhaven
Torch Red
12
Jul 18, 2015 11:41 AM
pretender
2011 - 2014 GT/CS
Jul 17, 2015 03:29 PM
