50 state legal exhausts
Old Jan 27, 2005 | 09:56 AM
Altoid's Avatar
Jackass
I live in California and I would rather get a legal system put into my car. I am already going to tint a bit and other things but exhaust seems to be an issue where I live. I know we get more leeway as we aren’t ricers, but I’d like to keep it legal. So let’s start on a working list of legal exhaust. As people fill in the info I will update the list. If I’m missing any companies or products let me know, and if any info is wrong let me know.
Magnaflow:
Regular Cat-Back Exhaust – 50 state legal.
Magnapacks - Not 50 states legal.
Magnaflow axleback - 50 state legal.
Bassani
50 State Legal X-Pipe
Muffler - ? (I assume they are legal since the X pipes are).
Borla
Headers are 50-state
Cat-Back (I assume they are legal since the headers are).
JBA
Old Jan 27, 2005 | 10:30 AM
dallasw77's Avatar
I'm in the same boat Altoid. I would like to know more about any exhaust that we can use out here in Cali.
Old Jan 27, 2005 | 10:42 AM
friedmaster's Avatar
I think this should be a sticky or something and make a master list.
The Magnaflow axleback is also street legal. Then again its the same thing without pipes from the cats.
Old Jan 27, 2005 | 06:49 PM
Ranger's Avatar
[quote=friedmaster,January 27, 2005, 11:45 AM]
After reading this, I checked on Virginia, from what I read, in this state, almost without exception, if its is not stock, it can be considered illegal. Could not find what the exceptions were. Apparently this month, a bill is being submitted to allow any exhaust if under 95 decimals.
Old Jan 28, 2005 | 09:31 AM
gnn60gt500's Avatar
Here are the exact laws pertaining to CA-
1. YOu can not remove the facotory converters at this time.
2. Exhaust must be under 95db using test procedure J1169
I can not speak for the other brands, however I can tell you that we do the db testing to make sure our catbacks are within the legal db limit.
The Magnapack however as noted is not within the legal limits.
You want to be careful when people claim exhaust is 50 state legal because when they are saying that 99/100 times they are reffering to emissions only...
not to sound.
Brent
Magnaflow Performance
Old Jan 28, 2005 | 09:52 AM
holderca1's Avatar
I could be wrong, but I think this is a federal law regarding removal of the converters.
Old Jan 28, 2005 | 12:33 PM
TKEUofM's Avatar
Is it just a California law, or is it every state?
I did a Google search and am having a hard time finding anything with a clear answer.
Old Jan 29, 2005 | 08:57 AM
dallasw77's Avatar
In Calif. can we use headers? Will they fail visual or ? If you can use headers with the stock cat conv. would that be legal?
Old Jan 29, 2005 | 09:14 AM
wild stray's Avatar
In California you can use headers only if they are C.A.R.B. certified. :notnice:
Old Jan 29, 2005 | 09:54 AM
dallasw77's Avatar
Ok someone get on it!!!
Old Jan 29, 2005 | 10:10 AM
wild stray's Avatar
JBA cat4ward shortys, but no good info out of them yet.
Old Jan 29, 2005 | 10:30 AM
holderca1's Avatar
Originally posted by holderca1+January 28, 2005, 10:55 AM--><div class='quotetop'>QUOTE(holderca1 @ January 28, 2005, 10:55 AM)</div><div class='quotemain'><!--QuoteBegin-gnn60gt500@January 28, 2005, 10:34 AM
[/b][/quote]
I had thought the law was you can't remove them until $50k miles unless they are defective. Will try to find more info.
Old Jan 29, 2005 | 10:34 AM
holderca1's Avatar
Found more details:
In August 1986, the U.S. Environmental Protection Agency (EPA) issued new proposed guidelines for the construction, efficiency and installation of aftermarket converters. The EPA guidelines state that replacement converters may be installed only in the following situations:
1. The vehicle is missing a converter.
2. A state or local inspection program has determined that the existing converter needs replacement.
3. The vehicle is more than five years old or has more than 50,000 miles and a legitimate need for replacement has been established and documented.
Old Jan 29, 2005 | 10:45 AM
wild stray's Avatar
[quote=holderca1,January 29, 2005, 9:37 AM]
Found more details:
1. "The vehicle is missing a converter."
That's easy enough!
Old Jan 30, 2005 | 08:56 AM
loudog's Avatar
I live in SoCal, and went with the 50-state legal Bassani X-pipe, and the Bassani Quiet Thunder cat-backs (also 50-state legal).
If going with Bassani, only the QTs are street legal (in most states). Believe me, they are not too loud - hardly notice them at idle or cruise, but they come to life when you whomp on the gas!
The Bassani Street Competition and Racing models are not.
Here's a link to their models: Bassani Mufflers
Of course, I retained the factory catalytics.
iliveonnitro
Oct 7, 2021 06:31 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 24, 2015 08:15 PM
