40 amp BAP work for our cars?
As the title says. I found a great deal on a 40 amp BAP, but will it be ok for my 08 GT? I was under the impression that you use a 40 amp (opposed to a 20 amp) for dual pumps.
I've been using a 40 amp BAP for over a year and it works like a charm. If you're going over 500 rwhp I would recommend dual fuel pumps instead of the BAP. One or the other under 500 rwhp, you don't need both.
Sounds great! Thanks a lot!
redfire did you wire yours up with a boost/vacuum switch or always on? im going to be running a 125+ hp shot of nitrous and will b running a bap (bought from brenspeed...)
You should ask Dave at Brenspeed, but I can tell you for blown applications they run the BAPs "always on" at the highest setting.
Yes a 40amp BAP will work on a Dual Pump setup, and we also like to run them 100% all the time.
Originally Posted by Derek@DRI
(Post 5608184)
My fault, yes it will work on a stock single fuel pump.
