4.10 gears with automatic
I just took my auto back to the dealer because it started leaking at the front of the case and it was also making a turbine whining sound through the console area. They stated that the case was broken on the transmission and replaced the whole transmission. They also said that there was a problem with the clutches. My question is has anyone installed 4.10 gears with an automatic and then had transission problems. I only had 100 miles after the gear change before it happened. Other mods include ud pulleys, sct tuner, jlt cold air. I called SCT and they told me that the increased pressure for a firmer shift actually helps the transmission so I ruled that out. Please give me some feedback as I am considering going back to the stock gears. And it does have a slight gear whine on deacc. but it is tolerable. Thanks again.
Originally posted by Blazing Saddles@July 21, 2005, 4:07 PM
10,000 miles and no problems.
Rando
8/25/21 11:12 AM
