4.10 gear
IMO, I would stick with FRPP. There seems to be fewer issues with those versus other brands.
Originally posted by I8URVTEC@January 19, 2006, 12:01 PM
Where did you buy yours from and how much did the install cost?
Originally posted by Fordracing200@January 20, 2006, 9:27 AM
I'd buy a set of pro 5.0 rearend gears, everyone seems to break the FRPP ones
I dont seem to know anybody who has broken frpp gears... hmmmmm
-Dan
yeah mine has been apart twice. i used two different brand gears and still have the same issue. i think the real problem is in the posi unit. ford had an issue in the explorer also which has the same lsd unit 31spline. now the mustang has the same type problems. i noticed when rotating the ring gear my backlash would vary as much as .006! it was the same with both sets of gears. the only thing i can think of that would cause it to vary like that is it's wobbling. only way it can wobble is the carrier must be machined wrong. ford did some dumb stuff trying to get rid of the noise in the 05-up mustangs did you notice the panhard bar is filled with sand,axle dampners and that aweful 40lb two piece driveshaft. all to get rid of gear noise. anybody replaced theirs with an eaton? any noise issues?
Rando
8/25/21 11:12 AM
