3500 TC INSTALL
#61
Thanks for the feedback...
I did not get a flex plate cause i won't be using nitrous... the plate i'm talking about is the stock plate between TC and transmission it has 8 lugs and nuts and i wanted to know the torque specs for that! My bro put it on anyways and used his own judgement hope it was accurate! He said it bolt on just fine!
#63
never mind my ignorance i got confused with anti balooning and flex plate oh well... any feedback on trans oil?
So how do you replace the trans fluid after you have instaleld a TC? Is it hazardous to put a different brand of ATF in the transmission and mixing it up...? The only thing I can find here is the Amsoil universal... Please enlighten!
#64
I used the standard Motorcraft fluid. I believe all types of fluid mix and will not cause any issue. If I was you I would pull the pan and drain that fluid plus put in a new filter. You fill with a hand powered fluid pump in the side of the transmission until it comes out out the fill plug. Run the car for a few minutes and add fluid if needed. Once it comes out of the fill port on the side of the trans it is full.
9/10/15 12:44 PM
