20x10 rear: will 265/35/20 fit?
thanks for the info.
i was comparing wheel/tire diameter and actually 265/35/20 is closer to stock height than 275/35/20.
275/35/20 is about 1/2" too high.
thanks again! happy new year!!
I have 285/30R20s on my ride an dit fits PERFECT!!!! a 265 on a 10" rim will look silly as the sidewall will be bowed.
As far as tire size affecting the speedo and such, I have not had any issues with my wheels. The factory computer can allow a 10% difference in tire size.
Good luck regardless I know you have been looking at a lot of wheels, what have you decided?
- Jesse
- Jesse
- Jesse
- Jesse
that would be back if the sidewall is bowed with the 265. i saw 265/35 on the rear of a porsche once. not sure if it was 10" wide though...and it was perfect...
i like 285/30/20 a lot but its like 1/2" shorter than STOCK wheel/tire diameter so, i wanted to keep it close. 275/35 is 1/2" too high...but i guess either way is good.
you got pics of your rear? thanks!
