14" brakes
Old Jun 10, 2007 | 06:04 PM
martin fink's Avatar
14" brakes
Will be installing 14 "big brakes on my 07 with 18 "stock wheels if I need a spacer to clear calipers in front do I put spacers on the rear to.Thanks
Old Jun 10, 2007 | 09:54 PM
MooStang05gt's Avatar
Are you going 14" on all four corners..?? If you need a spacer in the front then you will need one in the rear. If the 14's are in the front only, I wouldn't think it necessary to use one in the rear.
It would be a matter of personal preference, I would think..
Bobby M.
Old Jun 11, 2007 | 06:01 AM
ren274u's Avatar
you will need spacers to clear them, you might want to put them on the rear too unless you dont mind the look of having the front wheels stick out more than the rear.
Old Jun 11, 2007 | 11:35 AM
StillenMustang07's Avatar
Authorized Advertiser
It will depend which kit you are installing and which 18" factory wheel you have. To give you an idea the 18" fanblade wheel and our 14" 4-piston kit will fit with only a 3mm spacer. I believe that the bullit rim will require a much larger spacer (20mm+)
Old Jun 11, 2007 | 01:04 PM
MaverickMLFD371's Avatar
my 14" Baer GT-Plus upgrade kit required 1" wheel spacers to clear my 18" stock bullits
Old Jun 17, 2007 | 12:47 PM
The install is done .What a difference.Stainless lines .still have to do the breakin set but the install was strate forward.spacers were needed and a set of lugnuts .
boz
Oct 1, 2015 04:47 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 8, 2015 10:45 AM
