05 Mustang on the juice
little to scary for me.... I'm a firm believer in nitrous....use it to go tens w/ my 92...but what scares me is the plastic intake.......kaboom
blew my 99 gt intake into about 1000 pieces....suposedly fail safe direct port kit...
didn't work too well
Yeah, the intake is the only thing that was damaged...blew apart at top where the C&L elbow was mounted...thankfully.
I found an intake on ebay for 200. put it on, got rid of the nitrous and traded it in on my F250 Diesel 4X4....which in turn I traded for my 05.
Plastic intakes are not forgiving. I've had two back fires on my 92. The first one blew out the throttle body after I let off the gas and folded the butterfly backwards...was a simple fix, at least it didn't blow the intake up....and one time I blew the air box into a million pieces.
-2 times out of 5 years of spraying isn't bad...but that's the chance you'll take w/ a plastic intake, it only takes one backfire to destroy them.
Originally posted by 2005MustangGT@January 13, 2005, 7:35 PM
heres a pic of my 99
Two times in five years is too much for me since I'd be walking to work.
99GT best on drag radials was 12.20 at 111, bfg 275's
3.55
h-pipe w/ flow masters
cold air "if you count that"
timing adjuster / pulleys
nitrous (125 shot)
___________________
ran the grey 92 tonight, ended up going 10.70 @ 125, best so far
edelbrock heads
ecam
3.73's
150 shot
other bolt ons...etc
stock block, bottom end
stock 120,000 mile t-5,
26x11.5 et streets
1.47 60 ft
3.55
nitrous (125 shot)
___________________
edelbrock heads
ecam
3.73's
150 shot
26x11.5 et streets
1.47 60 ft
7/20/15 06:26 AM
