05 Mustang on the juice
Old Jan 12, 2005 | 01:51 PM
joeuser42's Avatar
Livernois Motorsports has a few pics of one of their customer's 05 Mustang GT on the juice.
Old Jan 12, 2005 | 02:21 PM
adrenalin's Avatar
nice video...
Old Jan 12, 2005 | 05:12 PM
05_John's Avatar
Would have been nice to see the dyno and numbers on the bottle!
Old Jan 12, 2005 | 05:23 PM
2005MustangGT's Avatar
little to scary for me.... I'm a firm believer in nitrous....use it to go tens w/ my 92...but what scares me is the plastic intake.......kaboom
blew my 99 gt intake into about 1000 pieces....suposedly fail safe direct port kit...
didn't work too well
Old Jan 12, 2005 | 06:40 PM
Nathan_H's Avatar
ouch
Old Jan 12, 2005 | 08:23 PM
joeuser42's Avatar
Was the intake the only damage? How much $$$ did that set you back? Just curious since I was thinking about a 100-150 shot sometime in the future.
Old Jan 13, 2005 | 05:29 PM
Yeah, the intake is the only thing that was damaged...blew apart at top where the C&L elbow was mounted...thankfully.
I found an intake on ebay for 200. put it on, got rid of the nitrous and traded it in on my F250 Diesel 4X4....which in turn I traded for my 05.
Plastic intakes are not forgiving. I've had two back fires on my 92. The first one blew out the throttle body after I let off the gas and folded the butterfly backwards...was a simple fix, at least it didn't blow the intake up....and one time I blew the air box into a million pieces.
-2 times out of 5 years of spraying isn't bad...but that's the chance you'll take w/ a plastic intake, it only takes one backfire to destroy them.
Old Jan 13, 2005 | 05:32 PM
heres a pic of my 99
Old Jan 13, 2005 | 06:27 PM
wild stray's Avatar
Old Jan 13, 2005 | 11:23 PM
joeuser42's Avatar
sweet ride!
Two times in five years is too much for me since I'd be walking to work.
Old Jan 14, 2005 | 04:25 PM
AnotherMustangMan's Avatar
Cam Tease
What kind of et's were you getting with your 99 prior ka-boom?
Old Jan 14, 2005 | 09:52 PM
99GT best on drag radials was 12.20 at 111, bfg 275's
3.55
h-pipe w/ flow masters
cold air "if you count that"
timing adjuster / pulleys
nitrous (125 shot)
___________________
ran the grey 92 tonight, ended up going 10.70 @ 125, best so far
edelbrock heads
ecam
3.73's
150 shot
other bolt ons...etc
stock block, bottom end
stock 120,000 mile t-5,
26x11.5 et streets
1.47 60 ft
Old Jan 15, 2005 | 06:39 PM
racrguy's Avatar
People that I've talked to that run a fairly large shot with the plastic intakes drilled a 1/2 inch hole in the lower-rear section of the intake then they put a rubber plug in the hole. That way instead of the intake blowing up all it did was pop out the plug.
Old Jan 15, 2005 | 10:04 PM
joeuser42's Avatar
Ahh, sort of like burst panels. I've seen burst panels for carburetors. I wonder if there's such an animal for EFI.
Old Jan 15, 2005 | 10:37 PM
DozerzPony's Avatar
Are there any numbers for the 05 w/ NO2? Is it a 2005 specific kit or did it have to be modified?
Old Jan 18, 2005 | 09:58 AM
-FROG-'s Avatar
Probably one of the coolest flame jobs I have seen! SWEET!!!!!!!
Old Jan 18, 2005 | 04:13 PM
thanks frog, was a big fan of the tribal flames until we laid these out
took forever as you can imagine
Jim74656
May 1, 2023 02:15 AM
Jul 20, 2015 06:26 AM
dohc97
Jul 19, 2015 07:29 PM
Jul 17, 2015 05:40 PM
