From The Ford Salesman News and information directly from Ford dealers across the country. Also find a trusty dealership near you
Ford Salesmen Post Your Contact Info Here
When did the last 2006 roll off the line?
Old Jan 3, 2007 | 06:37 PM
The Reverend's Avatar
The date on the door of my Mustang is May 2006.
Is there a way to find the exact date that it was built?
Old Jan 3, 2007 | 08:51 PM
AFBLUE's Avatar
Dethroned Nascar Guru
What's the last 6 of your vin?
Old Jan 3, 2007 | 09:31 PM
Old Jan 4, 2007 | 05:57 AM
flashfearless's Avatar
Job 1 for 07's was June 4th. Work backward from there I guess.
Old Jan 4, 2007 | 08:02 AM
Ford world headquarters 1-800-392-3673
you can call that number give them your vin and they will tell you what day it was built on. I think its usally a few days after the date on the sticker in the door jam
Old Jan 4, 2007 | 09:41 AM
blkstang06's Avatar
interesting! very good info Glenn! I called the number my 06 GT build date was 06/02/06. Job1 for the 07's started on 06/05/06
Old Jan 4, 2007 | 06:40 PM
whats the date on your sticker??
Old Jan 4, 2007 | 08:35 PM
blkstang06's Avatar
Door tag 06/06
Old Jan 5, 2007 | 05:49 AM
If you also have a PDF image of your sticker, the border of the image contains a bar code and other stuff which doesn't not wind up attached to the window. If you follow the link for my window sticker, you will see a numeric blob of data in the lower right. Embedded in that number is the date when they *started* production on my car 20060718. There is another date on the sticker that you will find on the sticker on your car. In my case, it appears as 06 26 06. This is the *blended* date for the production of your car. Basically this means the date when Ford actually decided the schedule of when your car would be built. So, my car received its production schedule on 6/26. The reason there is a large gap between that and my production date is the two week vacation over July 4th. In most cases, the production is within 2-3 weeks of the blended date.
The car actually rolled off the line on 7/19. Here is another copy of the image of my window sticker...
Old Jan 5, 2007 | 07:52 AM
How do I get the .pdf file for my vehicle?
Old Jan 5, 2007 | 10:41 AM
You would have had to get it from your dealer.
Old Jan 7, 2007 | 08:41 PM
ponyent's Avatar
The parts department or service department at your delaer can give you a printout with all of that info on it if you supply them with your vin#.
Old Jan 24, 2007 | 01:36 PM
Emu Hunter's Avatar
Hiya Flash,
When you asked your dealer for the PDF file, did they know what you were talking about? Know any hints I can give my dealership as to where to look on their computer system? They didn't seem to know about this ability when I called (although they said they'd poke around and try to find it on there somewheres)
Thanks,
Justin
Old Jan 25, 2007 | 08:19 PM
kevinb120's Avatar
They can also usually order a new window sticker entirely including the border you peel off(with that info on it)
Old Jan 26, 2007 | 02:59 PM
kcsherman's Avatar
I just need your vin# and I can tell you by running an OASIS
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Evil_Capri
Sep 25, 2015 12:56 PM
BackroadGT
V6 Performance Mods
Sep 22, 2015 07:13 PM
