Mustang Motorsports All forms of racing and motorsports activity allowed!
Track Related Mods
Old 9/8/17, 03:52 AM
  #601
dmichaels's Avatar
It also depends on brake plans. Very very few 18"s will fit 6-pot brembos if you go that wsy. But they all will fit 4-pot.
Old 9/8/17, 06:53 AM
  #602
Bert's Avatar
Received 1,547 Likes on 1,060 Posts
Is there really any need for the 6-piston Brembos, with the bigger rotors? Seems like the 4-pot with the 14" rotors work fine on these cars.
Old 9/8/17, 01:30 PM
  #603
dmichaels's Avatar
I still am using oem 4-pot sonyes they are very capable. No real need for bigger, I prefer the path of 2-piece rotors and Ti shields with cooling and good pads. Works just fine for me!
Old 9/8/17, 05:43 PM
  #604
dmichaels's Avatar
Project rear diff cooler is underway
Should wrap it up tomorrow. I'll post a few more pics
Old 9/8/17, 07:17 PM
  #605
EF1
EF1's Avatar
No plans currently to go with the 6 pot calipers. The factory 4 pot Brembos are enough for me.
Old 9/9/17, 07:37 AM
  #606
EF1
EF1's Avatar
What were the deciding factors in adding the rear diff cooler?
Old 9/9/17, 09:20 AM
  #607
dmichaels's Avatar
The third time I blew the rear axle seal was my deciding point. Getting too hot at the track so it's a good durability mod
Old 9/9/17, 09:26 AM
  #608
EF1
EF1's Avatar
How does heat lead to a blown seal? I realize heat can increase pressure, but the rear ends are vented to relieve pressure.
Old 9/9/17, 11:57 AM
  #609
dmichaels's Avatar
I'm assuming the seal is rubber or silicone of some sort, as it heats it becomes less stiff and it'll eventually let loose. Plus these cars run the diff up in temp quickly which shortens fluid life. Cooler is better
Old 9/9/17, 12:05 PM
  #610
dmichaels's Avatar
Wired in my accusump and diff cooler pump / fan... now I can pressurize the engine oil before starting. Doing all the cooling and durability upgrades... tranny cooler and external oil cooler coming over the winter
Old 9/9/17, 12:38 PM
  #611
EF1
EF1's Avatar
Thank you for the additional explanation. That makes sense that the heat degrades the seals over time and they fail. I wasn't thinking about the effects of heat over time.
Old 9/9/17, 01:07 PM
  #612
dmichaels's Avatar
I could be wrong, the above is my assumption.
Worth noting, the drivers seal is the one that has failed and it's on clockwise tracks. I think that supports my theory that the seal sees stress and with high heat it loses the ability to seal properly
We shall see if my cooler setup helps!
Old 9/9/17, 06:19 PM
  #613
dmichaels's Avatar
All installed. Just have to tidy things up a bit and go drive.
Plan is to run a session with it off, grab some IR gun temps, then repeat with it running. Should be 20-30F cooler
Old 9/9/17, 06:34 PM
  #614
dmichaels's Avatar
And the toggles for it and the accusump!
Old 9/9/17, 07:16 PM
  #615
EF1
EF1's Avatar
That looks really good. It will be interesting to see how much cooler it actually runs and how much longer the axle seals last.
Old 9/10/17, 03:48 PM
  #616
EF1
EF1's Avatar
Installed a Steeda X-brace and pan hard bar brace this afternoon. They weren't in my plans for this summer, but when I saw the labor day sale prices I decided to move them up my list. The X-brace is bolted in for now. I plan to have it welded in place when I find someone that I trust to do the job.
Old 9/10/17, 04:08 PM
  #617
dmichaels's Avatar
Nice, what's the benefit of the panhard brace? Something I never considered.
Old 9/10/17, 06:04 PM
  #618
EF1
EF1's Avatar
It is supposed to stiffen the pan hard bar mount which is prone to under loading/deflection. It also provides some additional chassis stiffness in the rear. The stock brace, or lateral stiffner in Ford speaks is made of stamped sheet metal and is pretty flimsy. The Steeda brace is made from 4130 chromoly tubing. I am not sure how much of a difference it is going to make, but it was only $80 on the labor day sale, so I figured why not.
Old 9/11/17, 10:59 AM
  #619
dmichaels's Avatar
Gotcha, very cool
Old 9/11/17, 11:01 AM
  #620
dmichaels's Avatar
Measured some differential temps today at my track day... diff external find are around 175, fwd diff area (black) is 190, radiator inlet is around 175, outlet is 150. So cooling at least 25F.
Quick Reply: Track Related Mods
