Mustang Motorsports All forms of racing and motorsports activity allowed!
Track Related Mods
Old 9/12/17, 06:36 PM
  #621
5.M0NSTER's Avatar
Nice work Derek, well done on the cooling!
I finally got around to getting an oil analysis done for Castrol Edge 5W-50, with Ford Racing filter. I had 5100 miles on it (changes it before the car went into storage last fall), and 3 track days, or ~6h of track time on it. It did well. I like this oil. I think I'll be able to go 1 oil change per year with it based on these results.
Old 9/15/17, 06:16 PM
  #622
EF1
EF1's Avatar
Originally Posted by dmichaels
All installed. Just have to tidy things up a bit and go drive.
Plan is to run a session with it off, grab some IR gun temps, then repeat with it running. Should be 20-30F cooler
Do you have a few pics of how you plumbed the lines into the differential?
Old 11/1/17, 07:19 PM
  #623
5.M0NSTER's Avatar
Debating getting new rotors all around for next season. I currently have the Centric cryo treated blanks with ~16k miles on them, and 6 track days. That's not so much I guess, but is this too much cracking? What do you guys think?
Old 11/2/17, 08:43 AM
  #624
mustang5o's Avatar
Wired in my accusump and diff cooler pump / fan... now I can pressurize the engine oil before starting. Doing all the cooling and durability upgrades... tranny cooler and external oil cooler coming over the winter
Any chance you can do more of a write up on all of these cooler installs? Your homemade brake duct one was pretty good and what I used when I had my 2014 GT.
Old 11/8/17, 04:04 PM
  #625
Bert's Avatar
Received 1,498 Likes on 1,022 Posts
Originally Posted by 5.M0NSTER
. . . What do you guys think?
I think that looks kinda crazy . . . are those actually cracks in the rotor material, or just in the pad material that is bedded onto the rotor?
Old 11/8/17, 08:35 PM
  #626
fourdegrees11's Avatar
Yeah if that's actually the rotor itself your brakes could shatter at any minute! If it's just something on the surface, then I dont know. I've never seen that before.
Old 11/9/17, 01:48 PM
  #627
5.M0NSTER's Avatar
They are surface cracks. It's in the actual rotor material. Very shallow, but the cracks are starting to connect. The rotor still has good thickness, and these are 0.5mm deep. The rotor wall thickness is still at ~7mm, so I'm not too worried about them shattering. Usually rotors crack as the rotor cools down after a session.
For some reason the passenger side looks a bit worse.
I'll keep them till next season but replace them before first track day.
Old 11/22/17, 03:08 PM
  #628
dmichaels's Avatar
Are they really 0.5mm deep? They look like normal surface cracking with no propagating, which should be good for several more track outings.
Old 11/22/17, 03:11 PM
  #629
dmichaels's Avatar
Probably won't be doing anything more, the car is no more... was deemed totaled in late Sept. Lots of good times though!
Probably a year off from car stuff as I'm buying a new house and getting married. But the next one will be either a C6 Z06 or a 2008-2010 Viper
Old 11/22/17, 09:01 PM
  #630
5.M0NSTER's Avatar
Hey Derek, hope you're all right even though the car is no more. I had this sinking feeling that's what happened since we haven't seen you post in the last few months.
Care to share what happened?
Again, hope you were fine,the rest is just broken plastic and metal.
And congrats on the house and getting married! Car stuff can wait.
Old 11/23/17, 08:02 AM
  #631
mustang5o's Avatar
Hope you're OK. I presume this happened on track since it's mostly a track car. Did insurance cover it?
Old 11/23/17, 05:18 PM
  #632
dmichaels's Avatar
Yup, I walked away unscathed. Feel free to PM
Thanks! Fun times in life. Very busy lately. I'm hoping winter 2018 I'll be comfortable enough to pick up the new car.
Will be the first season I won't participate in since 2009... weird...
Old 12/17/17, 09:23 AM
  #633
5.M0NSTER's Avatar
Since I need to replace my rotors and rear calipers, I decided to do the switch to 13.8" rear GT500 rotors. But I'm going the adapter route, not willing to take the axles out.
Got a set of these off ebay for $114
http://www.fast-autos.net/carparts/0...761005152.html
Old 12/17/17, 10:15 AM
  #634
mustang5o's Avatar
I've thought about going that route but would like to find some lightweight 2 piece rotors (that aren't crazy expensive) to go with it.
Old 12/17/17, 03:13 PM
  #635
5.M0NSTER's Avatar
Does anyone even make 2 piece rotors for the rear? I've only seen fronts so far. Fronts save you more weight for sure, but are ~$700 min for a set.
The rear GT500 13.8" rotors are $30 on rock auto, or $65 for high carbon steels.
Old 12/17/17, 03:22 PM
  #636
mustang5o's Avatar
I've seen them for the 11" rears for sure. Need to do more digging. Be kinda surprised if they don't since the GT500 could obviously use better braking as well.
Yep, bought some rotors there. I mostly use Centric Premium for track rotors except my Boss came with a set of Brembo 2 piece up front.
Old 12/17/17, 04:16 PM
  #637
EF1
EF1's Avatar
Pulling the axles really isn't a big deal. It only took a couple of hours start to finish when I did mine.
Old 12/22/17, 09:53 PM
  #638
5.M0NSTER's Avatar
I did some searching, and Gyro Disc does. But it's $400 a set in 11" or 13.8"
I was able to find $65 13.8" GT500 rear discs, so I think I'll pass for now.
You are right, and I'm just lazy . I did just replace rear diff fluid few months ago, so I want to be lazy some more.
Old 12/22/17, 10:11 PM
  #639
mustang5o's Avatar
Not a bad price for 2 piece rotors.
Old 12/23/17, 06:54 AM
  #640
EF1
EF1's Avatar
I understand. When I did mine I was due for a rear diff fluid change, so I was half way there. I also rebuilt the trac loc and replaced the stock diff cover with the Steeda finned aluminum version with drain and fill plugs. This allows me to be lazy on the fluid changes in the future.
Quick Reply: Track Related Mods
