Zaino and black gt
Old Apr 22, 2005 | 08:54 AM
MINO4.6's Avatar
What methods are being used to remove Zaino. I have applied Z2 and Z5 to my other 2 cars (one black, one white) and used an orbital buffer to remove it. Worked great , no swirl marks what so ever. But now its time to do my Black gt and worried about causing swirl . Anyone have experiance with this?
Thanks,
Tony
Old Apr 22, 2005 | 09:02 AM
outdoorstom's Avatar
Thanks,
Tony
Hey Tony, just curious why you'd want to remove Zaino?
Old Apr 22, 2005 | 09:07 AM
Fastrack's Avatar
Thanks,
Tony
I think he means he wants to remove it after he's applied it. Since Zaino does not require buffing. I've read you just need to use a 100% cotton towel. So I wouldn't bother with the buffer. I haven't even got my car yet. But did receive my Ultimate Zaino kit yesterday
Old Apr 22, 2005 | 09:40 AM
rhoover2's Avatar
No need for a buffer! I just wiped mine off with a cotton towel. No swirls!
Old Apr 22, 2005 | 09:46 AM
MINO4.6's Avatar
Originally posted by outdoorstom+April 22, 2005, 11:05 AM--><div class='quotetop'>QUOTE(outdoorstom @ April 22, 2005, 11:05 AM)</div><div class='quotemain'><!--QuoteBegin-MINO4.6@April 22, 2005, 8:57 AM
Thanks,
Tony
[/b][/quote]
no, no, I just meant after it hazes.
Old Apr 22, 2005 | 09:48 AM
Sorry, my bad.
Old Apr 22, 2005 | 09:56 AM
MINO4.6's Avatar
I tried using a cotton towel to wipe it off on the first car I did, but it took a lot of elbow grease so I switched to a buffer. I put the Zaino on very thin, and waited about 1/2 hour. Did I possiably let it dry to long or not long enough?
Old Apr 22, 2005 | 10:36 AM
snkbtn99's Avatar
100% cotton towel --white --- made in the USA ....
Old Apr 22, 2005 | 10:39 AM
Burke0011's Avatar
Big Falken Tires
Ditto - works great!
Old Apr 22, 2005 | 10:48 AM
Badandy's Avatar
No, not cotton.
Microfiber cloths from www.exceldetail.com
Old Apr 22, 2005 | 03:14 PM
rickoshay's Avatar
Originally posted by MINO4.6+April 22, 2005, 11:59 AM--><div class='quotetop'>QUOTE(MINO4.6 @ April 22, 2005, 11:59 AM)</div><div class='quotemain'><!--QuoteBegin-rhoover2@April 22, 2005, 11:43 AM
[/b][/quote]
Sounds like it wasn't dry. If you're not using the ZF accelerator, you can expect a 2-3 hour drying time, depending on temp and humidity. To test, simply take your finger and "swipe" the polish. If it's ready the swiped area will be clean, with no film on the paint surface. When you try to remove before it's dry all you are doing is smearing the polish around.
It should take very little effort to remove when properly dried. Zaino does not recommend powered buffers for removal. Check their site at www.zainobros.com for more info and tips.
kponypower
Jun 17, 2020 07:17 AM
cozyp828
Dec 13, 2017 05:53 PM
Evil_Capri
Sep 25, 2015 12:56 PM
