waterless carwash
Old Oct 28, 2013 | 05:45 PM
Jek57's Avatar
waterless carwash
Hi just wondering if it is possible to use waterless care wash stuff in the winter months? I live in upstate new york and hate to use automatic carwash places .Has anyone used waterless stuff in the winter?
Old Oct 28, 2013 | 06:03 PM
I do! If the car is really dirty I hit the touchless and do a follow up at home in the garage with the waterless stuff.
I use this stuff http://www.autogeek.net/ultima-water...ncentrate.html
and if you find the autogeek dude around here in his sig you will find a discount code
Old Oct 28, 2013 | 06:07 PM
Jek57's Avatar
Is your garage heated ?
Old Oct 28, 2013 | 06:28 PM
yeppers! I had a keroseane heater but installed a natural gas heater last year. It was under 200 bucks.
Old Oct 28, 2013 | 07:01 PM
Originally Posted by Glenn
You beat me to it Glenn.
Old Oct 28, 2013 | 09:55 PM
Xtian85's Avatar
I read you're more likely to scratch swirl the car for obvious reasons. The reason I haven't used it.
Old Oct 29, 2013 | 03:27 PM
Autogeek.net's Avatar
Former Vendor
Proper technique is key.
A waterless wash is a very safe and effective method of washing your vehicle when a bucket and hose isn't available.
Pinnacle Liquid Crystal - The 10 Minute Waterless Wash AND Wax!
The goal while performing a waterless car wash is to safely remove dirt and grime without scratching the paint. Pinnacle Liquid Crystal Waterless Wash Concentrate with Carnauba creates a very slick surface so dirt and grime can safely be removed without scratching the finish. You always want to use an ample amount of product while performing a waterless wash.
Working one panel at a time, spray a liberal amount of product directly onto the surface and wipe clean with a microfiber towel. I like the Gold Plush Jr. Microfiber Towel because its pile is thick enough to trap dirt and grit without causing unnecessary drag.
Old Oct 29, 2013 | 04:10 PM
Diode Dynamics's Avatar
Former Vendor
What are your thoughts on ONR?
Nick C.
Old Oct 29, 2013 | 06:10 PM
I usually spray the whole side of the car and let it soak in for a few. Then wiper down. Don't let it dry on its own.
Old Oct 29, 2013 | 08:15 PM
Xtian85's Avatar
I see, I will try this out soon. I have both ONR and Pinnacle, but just never had the courage to use it.
Old Oct 30, 2013 | 02:24 PM
MarcHarris's Avatar
Detailing Guru
I also agree that technique means more than anything. I know there are a lot of pros who use and believe in rinseless and waterless washing techniques, but I'm not one of them. It's past my comfort level.
Old Oct 31, 2013 | 02:23 PM
mikenapoli's Avatar
While I always prefer a traditional two-bucket hose wash when possible, it's not always an option. In cases where it can't be done, I personally am more comfortable using a rinseless wash such as ONR over any waterless washes. At least there is a minimal amount of water to flush heavier contaminants off the surface. But if you plan on doing this in the winter months, you'll have a lot of salt on your car that is beyond what I'd consider safe for rinseless or waterless. Go to a coin-op car wash and use ONLY their pressure wash feature (not the scrub brush!!!!) to blast most of the salt and road grime off the car. Then when you get home, proceed with your rinseless ONR wash.
1999 Black 35th GT
Feb 23, 2016 04:52 PM
FromZto5
Oct 2, 2015 10:07 AM
Nocturnal'14
Jan 16, 2015 06:34 PM
Autogeek.net
Oct 22, 2013 01:41 PM
Glenn
Dec 24, 2010 08:39 PM
