Removing sap
Old Oct 10, 2008 | 10:54 AM
viiStang's Avatar
Removing sap
I found a drip if sap on the side of my car and it looks like there are a few paint chips within the sap.
Can anyone recommend a good way to remove the dried out sap on my car without making it worse? Also what would be a good wait to fix the chips of paint? I'm guessing just some touch up paint would do. I also noticed some small nicks on my hood too.... Color is black.
Old Oct 10, 2008 | 11:34 AM
cop on my back's Avatar
I used an industrial cleaner called Slapshot, it is made by Walter, a German company. Basically a highly evaporative solvent that leaves no residue. Worked on sap like nothing I have ever seen before. Failing that, maybe lighter fluid. I don't think you have to worry about the paint, but it will strip the wax off. There are specific products out there to get sap off, but they don't work as well as industrial stuff.
Old Oct 10, 2008 | 01:31 PM
tdbrown75's Avatar
Clay bar? I have removed light sap using a clay bar with no ill effects, but it had only been there for a few days.
Tim
Old Oct 10, 2008 | 01:53 PM
Tiberius1701's Avatar
I have used regular old paint thinner-not lacquer thinner though, it is too aggressive. Wax will have to be reapplied.
Old Oct 10, 2008 | 02:10 PM
WaltM's Avatar
Stoner Bug & Tar Remover.
Old Oct 10, 2008 | 02:23 PM
GrnT's Avatar
Naptha. You can get it at the hardware store. Or Claybar.
Paint Pen for chips I guess. Thats what I did.
Good luck on the chips.
Old Oct 10, 2008 | 03:10 PM
Javdog's Avatar
Claybar will work fine and no solvents in it just make sure to wax after the claybar cause it will remove any wax on the paint.
Old Oct 10, 2008 | 06:13 PM
topbliss's Avatar
good old fashoned hand wash with a good quality liquid car soap... Or any of the spray on detail sprays will get off the light sap spots too
Old Oct 10, 2008 | 09:13 PM
yur1279's Avatar
I used a turtle wax bug/tar/sap remover.
Old Oct 11, 2008 | 04:45 AM
colbymh's Avatar
I must ask for a clarification. Are you talking about SAP= Seminal Acid Phosphatase? orrr SAP= as in tree goo?
Other than that, there is a product called "California Orange" that I use. My neighbors own a professional auto care business and are experts in detailing. It's a spray that works great and specifically mentions tree sap.
Old Oct 11, 2008 | 05:23 AM
pilatti1's Avatar
I would hand wash, Stoners Bug Cleaner, Clay and then a good wax, should take the sap out and look much better, for the chips some touch up paint but use a toothpick to apply it to the really small chips as the point of the toothpick is much finer then a brush or paint pen.....good luck & post some before & after pics
Old Oct 11, 2008 | 05:26 AM
stangster's Avatar
Hand wash with Ajax dish soap, that will get rid of the sap. If the paint doesn't feel smooth to the touch after washing and drying, use a claybar. After doing these, rewax.
Old Oct 11, 2008 | 11:16 PM
make sure you wash it with a regular car specific soap after the ajax if you use that
I'd just use a regular wash, claybar, then polish to get out any stains, and then some wax. search around for a product called Langka, I've never personally used it, but I've seen good results from it for your paint chips
Old Oct 13, 2008 | 10:41 AM
viiStang's Avatar
Ok so I used Nu Finish car wash, then got some Liquid Clay Bar (couldn't find any regular clay bars) and Wax, got some of it out but that sap is almost cemented into the paint. I scrubbed hard with the applicator with the clay bar and it doesn't come out. Also for the paint chips I tried to use a toothpick and pen and it looks crummy. I might have to take this into a shop and they'll probably charge me $300 for this crap.
Old Oct 13, 2008 | 11:04 AM
WaltM's Avatar
Try using bug and tar remover for the sap. Goo Gone if you have any.
Old Oct 14, 2008 | 09:10 AM
Javdog's Avatar
Liguid clay bar will not work I have tried it before and it would not remove small dots of sap but once I used the clay bar with some detailer it removed all the small dots of tree sap, try to find some claybar before you spend money on a pro. because they will probably use a claybar, try to find some and dont give up.
Javier
Old Oct 15, 2008 | 09:32 AM
adrenalin's Avatar
Well if you do it yourself, and properly, you will save some money. Get a real claybar, not that liquid stuff. It does not work the same. Once you have used the clay bar the sap should be completely gone. Pick up the Langka paint repair kit from autogeek.net. You can easily fill in those chips and then use the blob eliminator to fix it. Total cost to you is just over $50.00. Another member here was going to get his rear fender painted since it was scratched. I convinced him into getting the langka kit and he is very happy with the results.
Antigini-GT/CS
Oct 5, 2015 09:43 AM
jim010
Sep 14, 2015 10:15 PM
Sep 10, 2015 12:44 PM
